We are currently using Windows Live Maill on Windows 7. Would like to move to eM Client so I downloaded and installed it so we can try it out before upgrading to Pro.
Windows Live Mail has no problems checking or sending mail.
eM Client has the exact same settings, but will not send mail. Keep getting an error about not connecting to the server.
I have completely uninstalled any antivirus and that didn’t help (we had eSet and am going to re-install since it didn’t make a difference). When I use the eM Client diagnostics, its shows that IMAP is good, but still can’t connect to SMTP or fix it.
Any suggestions as to where I should start looking for an answer?
Paul
