I see several threads on M365 calendars but don’t see much progress. So I’m trying to bring this to someone’s attention so we can get it fixed
I add a user’s calendar to my calendar view in OWA. The name of that user then shows up in em Client, however when I select that user’c calendar I get an error (red triangle) upon syncing.
The error reads:
[Microsoft Graph] Synchronizing folder ‘Environ/People’s Calendars/[Calendar Name]’ failed due to the following error: The specified object was not found in the store.
I’m also not seeing the other users’ calendars in the mobile app.
Hi @George_Fehrenbach1
This error means Microsoft’s server didn’t let eM Client read that calendar. A common reason is the permission the calendar owner gave you. If they only shared their free/busy time, the calendar shows up in Outlook on the web, but its events can’t be read by other apps.
In Outlook on the web, ask the calendar owner which permission they gave you, for example “Can view when I’m busy”, “Can view titles and locations” or “Can view all details”. If it’s only free/busy, please ask them to change it to “Can view all details”. Then in eM Client right-click that calendar > Properties… > Repair, and let it sync again.
Your eM Client version (Menu > Help > About) and your operating system.
If the error stays, a log so our developers can see exactly what Microsoft returns:
Go to Menu > Settings > Advanced > Logging and click Clear Logs.
Under your Microsoft 365 account, tick Microsoft Graph.
Restart eM Client and click the shared calendar so the error appears.
Go to Menu > Help > Open log directory
Attach the files
For the mobile app: are you on iPhone or Android, and which app version? We’ll check the mobile side separately.
I’m seeing the same issue and won’t be getting any permissions to “Can view all details”. I don’t actually care that these are brought into Em Client and I would love a way to be able to choose which calendars sync to disable some from syncing
