I have just upgraded to version 10.4.5674, and nearly all my contacts have gone.
In general, all my contacts are kept as local contacts (local folders).
There are couple of my workplace contacts (Exchange Web) visible, where there should be hundreds and two from outlook.
All Contacts shows a total of five.
The various options in the contacts folder are selected
Unfortunately, whilst I did have a backup, when I followed step one, the new backup overwrote the previous one. I discovered that the backup setting was set to keep one back up.
However, I do have EmClient on another machine. I was able to export addresses from there to the new machine. Admittedly I rarely use that PC for emails, and so some of the addresses added recently are missing. The important bit is i have managed to get most of the addresses back.
I have also changed the backup settings to keep more than one back up.
A corrupt data base, or upgrade, does not really explain why the EWS service, has not picked up the email addresses from my work account.
