Linking with Zoho Calendar, Contacts & Tasks
Somehow I managed to link Zoho Mails for emails, but have not been able to link with the respective contacts, calendar and tasks as I do not see any option anywhere (the options are greyed out in emclient).
Please help with this.
Just to add, using custom/ personal domain and the domain is also hosted on Zoho Domains.
Online emails and calendar and tasks are working fine on browser.
To setup the Zoho CalDAV calendar in eM Client see the “below extract” from the Zoho help page
https://help.zoho.com/portal/en/kb/calendar/syncing-other-calendars/articles/setting-up-caldav-sync-in-zoho-calendar#Steps_to_configure_CalDAV_sync_for_eM_Client
Gto “Menu / Accounts” Then click “Add Account / Calendar / Caldav” on the far right and “click Next” in the manual wizard.
Then “enter the Account Address URL” as https://calendar.zoho.com/.well-known/caldav in the Server information dialog box.
The domain name ( calendar.zoho.com ) in the Account Address URL will vary based on the server region in which the account is hosted. Learn more)
Enter the “Zoho Calendar email ID in the Username” and “type the Password” and click Next.
If you have enabled Two Factor Authentication (TFA), you have to generate Application Specific Password to proceed.
Fill the Account name in the Account details sections and click Next.
Click the Finish button to create the account.
If you have trouble in using the server address while syncing your calendars, mail your queries with screenshots to [email protected]
Many thanks.
Let me try this and I will come back with the outcome.
Thanks again.
To setup the Zoho CardDAV contacts in eM Client see the “below extract” from the Zoho help page.
Go “Menu / Accounts” Then click “Add Account / Contacts / Caldav” on the far right and “click Next” in the manual wizard and enter the below url.
https://help.zoho.com/portal/en/kb/zoho-contacts/articles/carddav
Did you get your Zoho Calendar and Contacts working ?
Not yet.
Have tried few options but still not been able to get all the right steps.
Ok if it doesn’t work and you have a current active paid Pro, Personal or Business version, go to the VIP support page and login and lodge a support ticket and include this thread URL.
Hi, may I sugges to pay attention to the message left from @cyberzork with the table of database locations. Few month ago I was trying to connect to an EU database using a US domain :face_with_diagonal_mouth:
And yes, keep an eye on te Application Specific Password in case of TFA:
Where as when TFA is enabled any external clients can be authenticated with app password only. If the TFA is not enabled you can access using app password as well as zoho mail login password. (source: here)
Many thanks.
The contacts and calendar both are now in sync with Zoho contacts and calendar.
Thanks for your help.
To add here, there was a link which typically was hidden in a corner of the calendar settings page, which showed a different url (database location), different from what they have mentioned on their help/ support pages and when I used that; it started syncing immediately.
So, that’s the catch there.
Suggest everyone new to Zoho Calendar/ Contacts to login and see their calendar settings - on top of the page of API/ Sync and they will see the right link to be added.
But still, I find no solution to the Tasks and Notes.
Any help would be appreciated.
What was the Zoho Calendar & Contacts urls you used as an example for others ?
I would suggest to either email [email protected] to see if Tasks and Notes is actually supported in eM Client with Zoho, or if you have a current active paid Pro, Personal or Business version, go to the VIP support page and login and lodge a support ticket to query that way.
