Ciao a tutti, se io dovessi acquistare una licenza senza gli aggiornamenti a vita, non posso aggiornare la mia versione?
Lifetime upgrades means all versions are included at no extra cost. So version 9, 10, 11 etc.
A standard license on the other hand, is for a single version, so version 9 only. You get all version 9 updates included, but you can’t upgrade to version 10.
If you later decide to upgrade to version 10, you can do that, but you will need to purchase a version upgrade, and another version upgrade for version 11, etc.
