License for 3 devices?
I own a pro license with lifetime upgrades from 07/2020.
Looks like it’s only still for 1 device, but the actual pricing page says now 3 devices.
Does this mean I have to buy a new license (and new lifetime subscription) to use eM Client also on my new two devices?
regards…
eM Client ended the single Pro license and changed to the Personal 3 device license in July 2024 which is better value than just adding an additional device to the original Pro single license.
So if you might want to install eM Client on a third device later I’d suggest to purchase the Personal version rather than just add an additional device.
New Personal Subscription or One Time Payment Pricing options with or without Lifetime upgrade options. You can email [email protected] for any specific information.
You can also currently use the mobile apps on Android and iOS devices for free as well.
domingo 06 septiembre 2026 :: 1315hrs (UTC +0100)
Hey @d2o
There is also this other option that I have used as below:
skybat
¡Buena suerte!
Hablo español, luego portugués, inglés, francés, italiano y alemán
con conocimientos de varios otros idiomas incluidos griego y ruso
Yes, but I expected the lifetime subscription would also affect the amount of devices, from 1 to 3.
The adding of additional devices is quite expensive, so it looks like that you should consider buying the new license.
So, what does that mean? If any changes in the license in the future, that affect something in the usage or features, customers have to buy new licenses?
Suggest you email [email protected] for further assistance with those questions.
I did. Thank you.
Contacted the sales-team and the problem is now solved. Thanks a lot.
