Libero provider didn’t work for some days. Now it’s working and i can read/write email by browser, but I can’t do it by em Client: the imap account diagnostic response is bad.
Here the imap parameters:
host: imapmail.libero.it
port: 993
security criteria: SSL/TSL
Thanks to any one can help me,
Mario P
Go to Menu > Accounts and change the settings to the following:
IMAP:
Host: imapmail.libero.it
Port: 993
Security policy: Use SSL/TLS on special port (legacy)
SMTP:
Host: smtp.libero.it
Port: 587
Security policy: Force usage of SSL/TLS
Click on Save & Close when done.
If it still doesn’t work with those settings, as a test, can you completely disable any anti-virus, firewall, proxy or VPN, then try again. Sometimes even restarting your router may resolve this.
