Languages are missing from 9.2.1222.0 (eg. Greek)
Thank you
Thank you
viernes 25 noviembre 2022 :: 0853hrs (UTC +01:00)
Hey @chmichael
I just checked I have Greek available, suggest the first thing to do is to reboot eMC
¡Buena suerte!
skybat
Close and uninstall eM Client, making sure NOT to delete the database folder when asked. That will ensure all your data and settings are there later.
If it exists, delete the C:\Program Files (x86)\eM Client folder.
Download and install the latest version from here: https://www.emclient.com/dist/latest/setup.msi
Restart eM Client.
After updating the application it shows only english! (from inside the app)
I checked the folder the “el” translation folder is missing.
Step:
After the update you’ll notice that the Greek translation gone
Maybe it has to do with your windows locate or something ?
Thank you
Please follow my instructions above. I did not say to install an older version and then upgrade. Just uninstall and then download and install from the link I gave.
Yes, with your link worked with Greek translation!
