Try to open email and showing:- SQLite error-no such table: mail_data localmail contents? inconsistent data fail Can you help?
there are three things you can do to remedy this situation:
Update to the latest version available at http://www.emclient.com/dist/latest/s… and then go to Start -> Run and type the following:
“C:\Program Files\eM Client\DbRepair.exe” /checkall
or alternatively, if you use 64-bit system:
“C:\Program Files (x86)\eM Client\DbRepair.exe” /checkall -
Download a tool from http://www.emclient.com/tools/DbRepai… and run it.
Delete the database files located in C:\Users[your user name]\AppData\Roaming\eM Client (on Windows Vista/Windows 7) or C:\Documents and Settings[your user name]\Application Data\eM Client (on Windows XP). This will remove all settings though.
Regards
