Keep getting this everytime I start EM Client. Why do I get this and how do I remove or fix it?
Hello David,
this issue has been fixed in the newer releases. Please download and install this update > http://www.emclient.com/dist/v6.0.234…
Best regards,
can you black out my email - thanks forget too on upload
Im sorry, but I cant edit your post, you should be able to do it from your account though.
I can remove the forum topic if your problem has been solved now, though
yes thanks it fixed so far…just so you know, how come when you click on the update button inside em client it didn’t find that update? the link worked - but just letting you know update inside program said none avaiable
