NOTE: this is not a problem with eM Client but with the Juno SMTP server I am using. I would like to use the eM client but I can’t get it to work with Juno and I don’t want to switch to another service provider.
I have been unable to send mail using Juno’s email server, kept getting “Authenticate failure” using the same credentials as POP3 (which is working).
There appears to be a problem with Juno’s CRAM-MD5 authentication.
Here’s the Python session which demonstrates the problem and a hack to Authenticate using another method which works:
Thanx Gary, I was hoping for a way to select the authentication method, similar to the account setup used by Thunderbird (my current email client). I was really hoping I could em client to work, but alas I’m giving up.
I did contact Juno but don’t expect much help as their service is ancient! Thanx again.
Juno should either implement CRAM-MD5 or remove it from their server’s response options.
You can see what authentication methods the Juno server offered from your log above: nAUTH LOGIN PLAIN CRAM-MD5. So when eM Client connected, it would have chosen the most secure option from what is offered: CRAM-MD5. That is automatic and it is not possible to manually change to a less secure one like you can with Thunderbird.
So your server reported that CRAM-MD5 can be used, and eM Client sent the encrypted password, but because this server is misconfigured and actually doesn’t support CRAM-MD5, the encrypted password is rejected.
