When I open my Junk folder all the items are deleted before I can look at them. I see just a splite second flash of a list of items and then they are gone. So there is no way I can check to see if any messages are in there inadvertently - messages I do not want in there. And I can find no settings pertaining to the junk folder, and I can find no way to add an address to the whitelist. Help!
Hello Paul,
Are you getting the same behavior when Junk folder is opened trough ESP webmail interface?
Kind regards
