Hi all, how do I stop emails from appearing in my Junk folder?
Some personal emails are being junked when they should not be!
You too!! This issue reared it’s ugly head from nowhere several weeks ago and I have tried everything that has been suggested by eM Client and my email service provider (registrar) without resolution. If you every figure it out please post your key(s) to success and I will do the same. Good luck.
Normally when emails automatically go into your Junkmail folder, thats usually because of an auto detect AI Spam filter engine on your mail server end. Or you may have possibly filters or rules setup either online in your mailbox or possibly rules setup in eM Client moving inbox emails automatically.
So first check in eM Client rules via “Menu / Rules” (pc) or “Tools / Rules” (Mac). You can dblclick all the rules in there (except the Spam rule) to see what you have setup within each rule. Also along the top in rules you can select “Server Rules” in the dropdown, where depending on your type of account can also sometimes show you any server rules that you may have setup already.
Note:- For troubleshooting if there is any eM Client rule issue and you have too many rules to check, you could also eg: just “uncheck all the rules” and then Save and Close Rules and test.
Now if there is no local or server rules showing in eM Client Rules or disabling Rules in eM Client made no difference, then go online to your mailbox and check the filters / rules section there to make sure you haven’t accidentally setup something there moving inbox emails to Junk.
Failing that if you have no filters or rules setup online in your mailbox, then it will more than likely “just be your Server Mailbox AI auto detect spam engine” moving those emails directly to the junkmail folder from the Inbox when they arrive which in-turn will then show / mirror in the eM Client junkmail folder.
So the only way then is to go to your junkmail folder online and mark those emails as “Not Spam or Not Junk” which then your server mailbox will learn from then on to keep those emails in your Inbox.
Note: If those emails then keep going directly into your Junkmail folder online, you then contact your mailbox technical support for assistance as that side of thing is not eM Client related.
Many thanks cyberzork for your detailed response…
Paul
When I right click on the ‘Junk Email’ that I want to make not junk, I do not get a selection of either ‘Not Spam’ or ‘Not Junk’. What is the trick here?
Not in eM Client, but In your “Online Webmail Junk or Spam folder”.
So after selecting the message in your online webmail junk or spam folder, you should then see / have an option to select “Not junk or Not spam”. Once you do that, your online mailbox will then normally learn to keep that specific email “in your Inbox for future”.
If you can’t see that option, then contact your online webmail mailbox technical support.
hi
i have the same problem, i already talked to my service email provider, and marked all those email senders as not spam, and still appearing.
After my long talk to service provider, they told me that it should be done by emClient as server even in logs didint moved this as a spam.
Waiting solution, looking for any on forum as this is really annoying.
I am using a standard Gmail account with EM client 10.3.2619 .
My problem… I have repeatedly marked emails as “not spam”, in Google, and when I do that they arrive the normally in the Gmail inbox, but as soon as I open EM client, they get sent to the spam folder. I continue to mark them is not spam with both Gmail open and EM client open. Every time EM client refreshes may go back into the spam folder.
In other words Google is functioning normally but EM client repeatedly puts messages into the spam folder and there is no way to stop it please help!
PS I have no rules
