Junk mail—Entries are not taken into account, regardless of whether I move an entry from the junk mail folder to a registered customer’s inbox, or vice versa: Emails marked as junk still keep getting through
I’m not sure from your post if you mean real non junk emails are going to your Junkmail folder, or if you mean Junkmail is going to your inbox.
If you mean real sender emails are automatically going to the Junkmail folder and you haven’t setup a rule to do that, then that usually means “your mail server is detecting something suspicious or looks like spam in the senders email header, subject or body of the email” and automatically moving it into the Junkmail / Spam folder.
So for that scenario you need to “go online to your mailbox Junkmail / Spam folder” and “mark that email as Not Junk” which will then train your online mailbox to keep it in the Inbox for future. You might need to do that more than once till it learns depending on your specific mail server.
Or if you mean you are getting Junkmail in your Inbox then you can block that via “Menu / Rules” either by the senders email address, or by sender domain, or by header, subject or body using custom rules. You can eg: setup the rule to either automatically go to Junkmail folder or automatically go to deleted folder or to just delete it.
eM Client Rules
https://www.emclient.com/webdocumentation/en/10.3/eMClient/Default.htm#Rules/Rules.htm
You can also block senders Junkmail going in your Inbox via a blacklist which for V6-9 is in Rules or in V10 is via “Menu / Settings / Mail / Blacklist & Whitelist” as in the below support help page.
Blacklist documentation
