I receive junk mail quite often on my gmail account and I noticed that emClient doesn’t show any unread messages in that folder until I actually open it. Does it matter that I set it to show if unread?
show if unread
Is this a known issue? Will this be fixed?
I’m on 30-day trial of the Pro version.
It is intended behaviour.
If you want the Junk folder to sync without having to click on it you need to mark it for offline use.
To do that, go to Menu > Accounts then the IMAP tab for the Gmail account. Select both options under Sync Options, then click on Save & Close.
Tried that, and the wheel just keeps on turning. Is that how it is designed ? just keeps syncing every folder for ever ?
