Issues sending to gmail acccounts
WWhen sending emails to gmail recipients, I geta a “Mail Delivery System” error…
SMTP error from remote server for TEXT command, host: gmail-smtp-in.l.google.com (66.102.1.27) reason: 550-5.7.26 This mail is unauthenticated, which poses a security risk to the
550-5.7.26 sender and Gmail users, and has been blocked. The sender must
550-5.7.26 authenticate with at least one of SPF or DKIM. For this message ,
550-5.7.26 DKIM checks did not pass and SPF check for [ilinedesigns.com] d id
550-5.7.26 not pass with ip: [212.227.126.130]. The sender should visit
550-5.7.26 Prevent mail to Gmail users from being blocked or sent to spam - Gmail Help fo r
550 5.7.26 instructions on setting up authentication. y2-20020adffa4200000
0b002e419e9a783si1154609wrr.269 – gsmtp
I have tried sending with anti virus & fire wall off, changed my router. Same issue
Also, I can send via Outlook. So, the issue is emclient
hen sending to email recipienrts with gmail account
This is something you need to ask your email provider to fix. Just send them the message you quoted above and they will know what to do.
As i note in my post.
Sending via gmail using ms outlook works.
It is just emclient that it is not working with.
So it is an emclient issue.
