Hello.
I have:
MAC Big sur 11.2.3
New installed Em-client: 8.1.1083 (c197f89)
No antivirus installed.
Build in Mac mail application works fine, but emclient…
Can’t send emails.
Here is is log file.
Summary
[SMTP] MailClient.Accounts.SocketException: Connection failed due to the following reason:
“Unable to read data from the transport connection: The descriptor is not a socket.”
at MailClient.Protocols.Smtp.SmtpSendCommand.Connect (MailClient.Commands.WorkerStatus status) [0x00488] in :0
at MailClient.Protocols.Smtp.SmtpSendCommand.Execute (MailClient.Commands.WorkerStatus status) [0x0001f] in :0
at MailClient.Commands.Command.Process (MailClient.Commands.WorkerStatus status) [0x00015] in <53a4261dd91c48adbac40747337923a5>:0
EnqueuedStackTrace =
at MailClient.Protocols.Smtp.SmtpAccount+<>c__DisplayClass3_0.b__0 () [0x00000] in :0
at MailClient.Protocols.Common.AccountBase.RunIfOnline (System.Action actionIfOnline, System.Action actionIfOffline) [0x00000] in :0
at MailClient.Protocols.Smtp.SmtpAccount.SendAsync (System.Collections.Generic.IEnumerable1[T] items, System.Action
1[T] sentItem, System.Action`1[T] completed, System.Threading.CancellationToken cancellationToken) [0x00000] in :0
at MailClient.Accounts.BindingAccountBase.SendInternal () [0x00000] in :0
at MailClient.Accounts.BindingAccountBase.Send () [0x00000] in :0
at MailClient.Accounts.Mail.MailOptionsControl.Close (System.Windows.Forms.DialogResult result) [0x00000] in :0
at MailClient.UI.Forms.formAccounts.formAccounts_FormClosing (System.Object sender, System.Windows.Forms.FormClosingEventArgs e) [0x00000] in :0
at System.Windows.Forms.Form.OnFormClosing (System.Windows.Forms.FormClosingEventArgs e) [0x00000] in :0
at System.Windows.Forms.Form.FireClosingEvents (System.Windows.Forms.CloseReason reason, System.Boolean cancel) [0x00000] in :0
at System.Windows.Forms.Form.RaiseCloseEvents (System.Boolean last_check, System.Boolean cancel) [0x00000] in :0
at System.Windows.Forms.Form.WmClose (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Form.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at MailClient.Common.UI.Forms.ThemeForm.WndProc (System.Windows.Forms.Message& m) [0x00000] in <331624d8574542fcb37cf9c6103778a6>:0
at MailClient.Common.UI.Forms.BorderlessForm.WndProc (System.Windows.Forms.Message& m) [0x00000] in <331624d8574542fcb37cf9c6103778a6>:0
at MailClient.UI.Forms.BorderlessBaseFormWithToolbar.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.NativeWindow.WndProc (System.IntPtr hWnd, System.Windows.Forms.Msg msg, System.IntPtr wParam, System.IntPtr lParam) [0x00000] in :0
at System.Windows.Forms.XplatUICocoa.DispatchMessage (System.Windows.Forms.MSG& msg) [0x00000] in :0
at System.Windows.Forms.XplatUI.DispatchMessage (System.Windows.Forms.MSG& msg) [0x00000] in :0
at System.Windows.Forms.Application.SendMessage (System.Windows.Forms.MSG& msg, System.Boolean& drop, System.Boolean& quit) [0x00000] in :0
at System.Windows.Forms.Application.SendMessage (System.IntPtr hwnd, System.Windows.Forms.Msg message, System.IntPtr wParam, System.IntPtr lParam) [0x00000] in :0
at System.Windows.Forms.XplatUICocoa.SendMessage (System.IntPtr hwnd, System.Windows.Forms.Msg message, System.IntPtr wParam, System.IntPtr lParam) [0x00000] in :0
at System.Windows.Forms.XplatUI.SendMessage (System.IntPtr handle, System.Windows.Forms.Msg message, System.IntPtr wParam, System.IntPtr lParam) [0x00000] in :0
at System.Windows.Forms.Form.Close () [0x00000] in :0
at MailClient.UI.Forms.formAccounts.stripButton_ActionButton_Click (System.Object sender, System.EventArgs e) [0x00000] in :0
at System.Windows.Forms.Control.OnClick (System.EventArgs e) [0x00000] in :0
at MailClient.Common.UI.Controls.ControlToolStrip.ControlToolStripButton.PerformClick () [0x00000] in <331624d8574542fcb37cf9c6103778a6>:0
at MailClient.Common.UI.Controls.ControlToolStrip.ControlToolStripButton.OnMouseUp (System.Windows.Forms.MouseEventArgs e) [0x00000] in <331624d8574542fcb37cf9c6103778a6>:0
at System.Windows.Forms.Control.WmLButtonUp (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.ScrollableControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.ContainerControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.UserControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at MailClient.Common.UI.Controls.AutomationViewUserControl.WndProc (System.Windows.Forms.Message& m) [0x00000] in <331624d8574542fcb37cf9c6103778a6>:0
at System.Windows.Forms.Application.SendMessage (System.Windows.Forms.MSG& msg) [0x00000] in :0
at System.Windows.Forms.CocoaInternal.WindowsEventResponder.TranslateMouseUp (AppKit.NSEvent e) [0x00000] in :0
at System.Windows.Forms.CocoaInternal.WindowsEventResponder.MouseUp (AppKit.NSEvent theEvent) [0x00000] in :0
at System.Windows.Forms.CocoaInternal.MonoView.MouseUp (AppKit.NSEvent theEvent) [0x00000] in :0
at System.Windows.Forms.Mac.Extensions.DispatchMouseEvent (AppKit.NSView view, AppKit.NSEvent e) [0x00000] in :0
at System.Windows.Forms.XplatUICocoa.PumpNativeEvent (System.Boolean wait, System.Windows.Forms.MSG& msg, System.Boolean dequeue) [0x00000] in :0
at System.Windows.Forms.XplatUICocoa.GetMessage (System.Object queue_id, System.Windows.Forms.MSG& msg, System.IntPtr hWnd, System.Int32 wFilterMin, System.Int32 wFilterMax) [0x00000] in :0
at System.Windows.Forms.XplatUI.GetMessage (System.Object queue_id, System.Windows.Forms.MSG& msg, System.IntPtr hWnd, System.Int32 wFilterMin, System.Int32 wFilterMax) [0x00000] in :0
at System.Windows.Forms.Application.RunLoop (System.Boolean Modal, System.Windows.Forms.ApplicationContext context) [0x00000] in :0
at System.Windows.Forms.Application.Run (System.Windows.Forms.ApplicationContext context) [0x00000] in :0
at MailClient.Program.Main (System.String[] args) [0x00000] in :0
at MailClient.App.Program.Main (System.String[] args) [0x00000] in :0
How can I solve this issue?
