Issue: Can't set avatar for contact when zooming in
I’m on macOS 14.4 and latest eM Client 9.2.2230. I’m looking at an email. I create a contact for the sender that was not previously in my contacts. I then open the contact for the sender and edit the avatar for the sender. I set the avatar to a file from my computer. In the resulting popup, if I don’t use the slider to zoom in and just hit ok, the avatar saves. If I do slide and zoom in on the photo (which I want to do) and hit ok, the resulting avatar is just blank. If it makes a difference, the photo I’m trying to zoom in on is rectangular (portrait) and is a .jpg.
Feels like a bug - is there anything I’m doing wrong, or can this be looked into? Thanks in advance!
