Hi - new client - Mac user - I noticed Grammarly premium doesn’t work on the platform, but can you recommend any Grammarly-type product that works with Mac?
See @Gary response below in this query on Grammarly for Mac. I believe it’s still the case.
I haven’t personally seen anything else as yet working / integrating with eM Client for Mac.
@Gary post on this query.
“We were exploring Grammarly integration, but the only API they could supply was for web apps”.
As to your post title “Is there a Spell checker”
Yes there is an automatic spell checker you can setup via “Menu / Settings / General / Spell-checker” (PC) or “eM Client / Preferences / General / Spell-checker” (Mac). You can download the different dictionaries via the button option if your language is not available in the dropdowns.
Just a word to the wise - the spell checker in eMClient is not very good. It ignores commonly misspelled words and replaces perfectly good words with errors. Not sure why - seems like a pretty basic function. I have had to turn it off and only use if for final reviews. YMMV.
Can you give an example?
I see you are using a Mac.
“Correct spelling automatically” is a function of the macOS, not eM Client. You can disable it in the OS under keyboard settings.
