Invalid spelling mistake highlighting
The first word is every sentence is underlined as if it were a spellin mistake. This is very distracting.
It started happening yesterday. How can I make it stop?
by the way it does not happen if the first letter is lower case! See the attached image.
What version of eMC are you using?
MENU > HELP > ABOUT
9.2.1628 (a307a94)
Language is English(United Kingdom)
Ensure you have the correct language selected in the following places:
MENU > SETTINGS > LANGUAGE
MENU > SETTINGS > SPELL CHECKER
In MENU > SETTINGS > LANGUAGE, “Current Language” was showing “English (United States)”. I changed this by selecting “English” from the list. I also responded positively to an update prompt (the version is now 9.2.1735 (3d90379)) - so I am not sure which change caused the issue to go away but it is now ok. Thank you. For reference the two settings mentioned now look as below.,
