Hallo, could anyone tell me the reason for that irritating message? By the way It’s a test-version. It is reproducible at boot. Thanks.
Hi David, what version of eM client are you currently using with eM Client, can you please check the exact version number in Help > About? Also, when the error occurs, can you please switch to the Log tab in operations, copy the content of the error and submit the log to us here on the forum?
Paul
Hi Paul, thank you for answering quickly. The exact version is 6.0.21372.0
The protocol
19:19:31 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/[Gmail]/Alle Nachrichten
19:19:31 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Fertiggestellt
19:19:31 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/[Gmail]/Wichtig
19:19:31 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/[Gmail]/Alle Nachrichten/wichtig
19:19:32 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Fertiggestellt
19:19:32 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/wichtig
19:19:32 robrahnd@gmail.com [IMAP] Synchronisiere Nachrichten: Für Ordner robrahnd@gmail.com/Inbox
19:19:33 robrahnd@gmail.com [IMAP] Synchronisiere Nachrichten: Fertiggestellt
I couldn’t get more dates.
David
Hi David, thank you for the received log but unfortunately this doesn’t seemt o contain any additional details about the error, can you please copy the full content of the log when the error occurs and submit it to us here?
Paul
Hi Paul, sorry, there are no more data. So should I connect with Google/gmail? I don’t know what is wrong. All Mails always seems to be fetched from the Google Server to em Client. So what does the sreenshot mean after booting em Client?
Sorry for my english language.
Thank you
David
Hi David, the log tab has to contain more information about the issue, please copy the whole content right after the error occurs, use ctrl+a to select the whole content of the log and copy it out of the operations tab.
Paul
Sorry Paul, that’s all what I get. Sync-Vorgänge is empty. Fehler is the screenshot you know. Or I don’t know what you mean.
David
David, I need you to copy the content of the Log (Protokoll), Screenshot doesn’t display the whole error message, please use shortcuts to copy the whole content of the log and submit it here on the forum by pasting the content into your next reply.
Paul
Sorry, Paul, there are no more data in Protokoll. Could you send me a picture how it should be look like for example?
Thanks
David
Once again for you, Paul, that’s the whole content.
13:59:28 Online-Status: geändert zu Online wegen NetworkAvailability
13:59:28 robrahnd@gmail.com [IMAP] Nachrichten werden auf den Server hochgeladen: In Ordner robrahnd@gmail.com/Sent
13:59:28 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/
13:59:28 robrahnd@gmail.com [GData] Synchronisiere Ordnerliste
13:59:29 robrahnd@gmail.com [GData] Synchronisiere Ordnerliste
13:59:30 robrahnd@gmail.com [GData] Synchronisiere Ordnerliste
13:59:30 robrahnd@gmail.com [IMAP] MailExceptions.OperationException: Die Nachricht “” konnte nicht in den Ordner “Sent” hochgeladen werden. (Invalid Arguments: Unable to parse message)
13:59:30 robrahnd@gmail.com [IMAP] Nachrichten werden auf den Server hochgeladen: Fertiggestellt
13:59:30 robrahnd@gmail.com [IMAP] Synchronisiere die Nachrichtenmarkierungen: Für Ordner robrahnd@gmail.com/Sent
13:59:30 robrahnd@gmail.com [IMAP] Der Nachrichtenteil wird heruntergeladen…
13:59:30 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Fertiggestellt
13:59:30 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/Inbox
13:59:30 robrahnd@gmail.com [IMAP] Synchronisiere die Nachrichtenmarkierungen: Fertiggestellt
13:59:30 robrahnd@gmail.com [IMAP] Der Nachrichtenteil wird heruntergeladen…: Fertiggestellt
13:59:30 robrahnd@gmail.com [GData] Synchronisiere Ordner ‘robrahnd@gmail.com/Contacts/’
13:59:30 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/Gesendet
13:59:30 robrahnd@gmail.com [GData] Synchronisiere Ordner ‘robrahnd@gmail.com/robrahnd@googlemail.com/’
13:59:30 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/Gesendet/gekauft
13:59:31 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Fertiggestellt
13:59:31 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/Papierkorb
13:59:31 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/Personal
13:59:31 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/[Gmail]
13:59:32 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Fertiggestellt
13:59:32 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/[Gmail]/Alle Nachrichten
13:59:32 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/[Gmail]/Wichtig
13:59:32 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/[Gmail]/Alle Nachrichten/wichtig
13:59:33 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Fertiggestellt
13:59:33 robrahnd@gmail.com [IMAP] Synchronisiere Unterordner: Für Ordner robrahnd@gmail.com/wichtig
13:59:33 robrahnd@gmail.com [IMAP] Synchronisiere Nachrichten: Für Ordner robrahnd@gmail.com/Inbox
13:59:34 robrahnd@gmail.com [IMAP] Synchronisiere Nachrichten: Fertiggestellt
13:59:35 robrahnd@gmail.com [IMAP] Synchronisiere die Nachrichtenmarkierungen: Für Ordner robrahnd@gmail.com/Inbox
13:59:35 robrahnd@gmail.com [IMAP] Synchronisiere die Nachrichtenmarkierungen: Fertiggestellt
This is what I needed, thank you… Seems like the application is having issues while uploading a message to your server, maybe be due to a message size limit being exceeded, however your server is not accepting the message.
Please try to repair your sent folder, right click the folder in the left pane and select Properties > Repair and click on the “Repair” button. Wait for the application to resynchronize the folder and check if the issue reoccurs.
Paul
No Paul, after this still the same…
But thank you
David
- New installation?
Have you been importing any messages into the current google account or is this possibly an issue with a sent message? Are you using any security software on your computer, such as firewall or any antivirus with email protection features? If so, can you please try to temporarily disable such security element and check if the issue persists?
Paul
Your first sentence I couldn’t answer, because I don’t know. I switched off all funktions from G-Data Antivir for a while. - Still the same result.
Thank you
David
By the way. Other clients I tried doesn’t show this mistake. (using imap) Strange, isn’t it?
Each application handles thrown error differently , some hide connectivity issues completely, can you please enable IMAP logging for the problematic account in Tools > Settings > Advanced?
- Save the settings
- Restart the application
- Replicate the issue
Once the error reoccurs, please go back to the advanced settings window and submit the logs to us, using the “Send logs” button, once the error reoccurs, please submit the logs to my email, mcgregor@emclient.com with a reference link to this forum topic.
Paul
