Hi!
Great application, but one major issue - it gives trouble connecting to IMAP servers. Intermittent at the moment - it connects sometimes, sometimes fails.
I have connection to 3 different servers - one POP, 2 IMAP.
Most troubles are with Rackspace mail, which supposed to be configured to use SSL on port 993 (em client fails almost always). Allowed em client to fix this - it started using port 143 with “Use SSL/TLS if avail” and worked yesterday, but today it fails 75% of all times and connects the rest of the time. On few occasions all servers failed to connect, but this happens rarely.
I would switch to pro, but do not want to pay before the issue is understood and resolved. Hate to drop em!
BTW, built in diagnostics shows “OK” for IMAP connection, but connection does not happen and messages do not get downloaded.
Can I ask you for IMAP logs? Tools - settings - advanced, check IMAP, apply and restart eM Client.
then make same steps which leads to your issue and after that send logs… to [email protected] together with this topic’s URL in subject.
with regards
Jan
Hello Everyone,
we are getting this error while Microsoft outlook syncing with email server.
C:\PROGRA~1\MICROS~1\Office12\OUTLMIME.DLLIMAP: 17:24:00 [db]
Intializing connection [0x08fef808]
IMAP: 17:24:00 [db] Setting internal codepage to 1200
IMAP: 17:24:12 [db] Connecting to ‘newimap.eil.co.in’ on port 143.
IMAP: 17:24:12 [db] OnNotify: asOld = 0, asNew = 2, ae = 0
IMAP: 17:24:12 [db] srv_name = “eil.co.in” srv_addr = 10.10.1.45:143
IMAP: 17:24:12 [db] OnNotify: asOld = 2, asNew = 3, ae = 1
IMAP: 17:24:12 [db] OnNotify: asOld = 3, asNew = 4, ae = 0
IMAP: 17:24:12 [db] OnNotify: asOld = 4, asNew = 5, ae = 2
IMAP: 17:24:12 [db] OnNotify: asOld = 5, asNew = 5, ae = 4
IMAP: 17:24:12 [db] OnNotify: asOld = 5, asNew = 5, ae = 3
IMAP: 17:24:12 [rx] * OK Domino IMAP4 Server Release 8.5 ready Wed, 16 Oct 2013 17:24:12 +0530
IMAP: 17:24:12 [tx] dy7j CAPABILITY
IMAP: 17:24:12 [rx] * CAPABILITY IMAP4rev1 AUTH=PLAIN LITERAL+ NAMESPACE QUOTA UIDPLUS
IMAP: 17:24:12 [rx] dy7j OK CAPABILITY completed
IMAP: 17:24:12 [tx] LOGIN command sent
IMAP: 17:24:12 [rx] 88st OK LOGIN completed
IMAP: 17:24:12 [tx] mvqc LIST “” “”
IMAP: 17:24:12 [rx] * LIST (\Noselect) “\” “”
IMAP: 17:24:12 [rx] mvqc OK LIST completed
IMAP: 17:24:12 [tx] tdwa SELECT “INBOX”
IMAP: 17:24:12 [rx] * 8518 EXISTS
IMAP: 17:24:12 [rx] * 0 RECENT
IMAP: 17:24:12 [rx] * OK [UNSEEN 6374] Message 6374 is first unseen
IMAP: 17:24:12 [rx] * OK [UIDVALIDITY 1] UIDs valid
IMAP: 17:24:12 [rx] * OK [UIDNEXT 12652] Predicted next UID
IMAP: 17:24:12 [rx] * FLAGS (\Flagged \Seen \Answered \Deleted \Draft)
IMAP: 17:24:12 [rx] * OK [PERMANENTFLAGS (\Flagged \Seen \Answered \Deleted \Draft *)] Permanent flags
IMAP: 17:24:12 [rx] tdwa OK [READ-WRITE] SELECT completed
IMAP: 17:24:12 [tx] wtif FETCH 8518 (UID)
IMAP: 17:24:12 [rx] * 8518 FETCH (UID 12651)
IMAP: 17:24:12 [rx] wtif OK FETCH completed
IMAP: 17:24:12 [tx] v67f UID FETCH 11938:12640 (UID FLAGS)
IMAP: 17:24:13 [db] OnNotify: asOld = 5, asNew = 5, ae = 3
IMAP: 17:24:13 [rx] * 8001 FETCH (UID 11939 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8002 FETCH (UID 11940 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8003 FETCH (UID 11941 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8004 FETCH (UID 11942 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8005 FETCH (UID 11943 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8006 FETCH (UID 11944 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8007 FETCH (UID 11947 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8008 FETCH (UID 11948 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8009 FETCH (UID 11949 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8010 FETCH (UID 11952 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8011 FETCH (UID 11953 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8012 FETCH (UID 11954 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8013 FETCH (UID 11955 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8014 FETCH (UID 11956 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8015 FETCH (UID 11959 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8016 FETCH (UID 11960 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8017 FETCH (UID 11961 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8018 FETCH (UID 11962 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8019 FETCH (UID 11963 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8020 FETCH (UID 11965 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8021 FETCH (UID 11967 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8022 FETCH (UID 11968 FLAGS (\Seen $Forwarded))
IMAP: 17:24:13 [rx] * 8023 FETCH (UID 11969 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8024 FETCH (UID 11973 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8025 FETCH (UID 11975 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8026 FETCH (UID 11976 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8027 FETCH (UID 11977 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8028 FETCH (UID 11978 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8029 FETCH (UID 11979 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8030 FETCH (UID 11980 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8031 FETCH (UID 11981 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8032 FETCH (UID 11982 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8033 FETCH (UID 11983 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8034 FETCH (UID 11985 FLAGS ())
IMAP: 17:24:13 [rx] * 8035 FETCH (UID 11986 FLAGS ())
IMAP: 17:24:13 [rx] * 8036 FETCH (UID 11987 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8037 FETCH (UID 11988 FLAGS ())
IMAP: 17:24:13 [rx] * 8038 FETCH (UID 11990 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8039 FETCH (UID 11991 FLAGS ())
IMAP: 17:24:13 [rx] * 8040 FETCH (UID 11993 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8041 FETCH (UID 11994 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8042 FETCH (UID 11995 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8043 FETCH (UID 11997 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8044 FETCH (UID 11998 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8045 FETCH (UID 12000 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8046 FETCH (UID 12001 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8047 FETCH (UID 12002 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8048 FETCH (UID 12004 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8049 FETCH (UID 12005 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8050 FETCH (UID 12006 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8051 FETCH (UID 12007 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8052 FETCH (UID 12008 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8053 FETCH (UID 12009 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8054 FETCH (UID 12010 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8055 FETCH (UID 12011 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8056 FETCH (UID 12012 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8057 FETCH (UID 12013 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8058 FETCH (UID 12015 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8059 FETCH (UID 12017 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8060 FETCH (UID 12018 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8061 FETCH (UID 12019 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8062 FETCH (UID 12021 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8063 FETCH (UID 12022 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8064 FETCH (UID 12023 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8065 FETCH (UID 12024 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8066 FETCH (UID 12025 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8067 FETCH (UID 12026 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8068 FETCH (UID 12027 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8069 FETCH (UID 12028 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8070 FETCH (UID 12032 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8071 FETCH (UID 12033 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8072 FETCH (UID 12035 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8073 FETCH (UID 12036 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8074 FETCH (UID 12038 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8075 FETCH (UID 12039 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8076 FETCH (UID 12042 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8077 FETCH (UID 12045 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8078 FETCH (UID 12046 FLAGS (\Seen \Answered))
IMAP: 17:24:13 [rx] * 8079 FETCH (UID 12048 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8080 FETCH (UID 12049 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8081 FETCH (UID 12051 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8082 FETCH (UID 12052 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8083 FETCH (UID 12055 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8084 FETCH (UID 12056 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8085 FETCH (UID 12057 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8086 FETCH (UID 12058 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8087 FETCH (UID 12059 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8088 FETCH (UID 12060 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8089 FETCH (UID 12061 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8090 FETCH (UID 12062 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8091 FETCH (UID 12063 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8092 FETCH (UID 12064 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8093 FETCH (UID 12065 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8094 FETCH (UID 12069 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8095 FETCH (UID 12070 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8096 FETCH (UID 12072 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8097 FETCH (UID 12073 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8098 FETCH (UID 12079 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8099 FETCH (UID 12080 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8100 FETCH (UID 12083 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8101 FETCH (UID 12086 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8102 FETCH (UID 12087 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8103 FETCH (UID 12088 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8104 FETCH (UID 12089 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8105 FETCH (UID 12090 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8106 FETCH (UID 12091 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8107 FETCH (UID 12092 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8108 FETCH (UID 12093 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8109 FETCH (UID 12094 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8110 FETCH (UID 12095 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8111 FETCH (UID 12096 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8112 FETCH (UID 12097 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8113 FETCH (UID 12098 FLAGS ())
IMAP: 17:24:13 [rx] * 8114 FETCH (UID 12100 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8115 FETCH (UID 12101 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8116 FETCH (UID 12102 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8117 FETCH (UID 12103 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8118 FETCH (UID 12104 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8119 FETCH (UID 12105 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8120 FETCH (UID 12106 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8121 FETCH (UID 12109 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8122 FETCH (UID 12111 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8123 FETCH (UID 12112 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8124 FETCH (UID 12114 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8125 FETCH (UID 12115 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8126 FETCH (UID 12117 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8127 FETCH (UID 12118 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8128 FETCH (UID 12119 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8129 FETCH (UID 12120 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8130 FETCH (UID 12121 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8131 FETCH (UID 12122 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8132 FETCH (UID 12123 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8133 FETCH (UID 12125 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8134 FETCH (UID 12126 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8135 FETCH (UID 12127 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8136 FETCH (UID 12128 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8137 FETCH (UID 12129 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8138 FETCH (UID 12130 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8139 FETCH (UID 12132 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8140 FETCH (UID 12133 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8141 FETCH (UID 12135 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8142 FETCH (UID 12136 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8143 FETCH (UID 12137 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8144 FETCH (UID 12139 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8145 FETCH (UID 12140 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8146 FETCH (UID 12141 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8147 FETCH (UID 12142 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8148 FETCH (UID 12143 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8149 FETCH (UID 12144 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8150 FETCH (UID 12145 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8151 FETCH (UID 12146 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8152 FETCH (UID 12148 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8153 FETCH (UID 12149 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8154 FETCH (UID 12152 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8155 FETCH (UID 12153 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8156 FETCH (UID 12154 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8157 FETCH (UID 12158 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8158 FETCH (UID 12160 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8159 FETCH (UID 12161 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8160 FETCH (UID 12163 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8161 FETCH (UID 12164 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8162 FETCH (UID 12166 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8163 FETCH (UID 12167 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8164 FETCH (UID 12168 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8165 FETCH (UID 12169 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8166 FETCH (UID 12173 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8167 FETCH (UID 12177 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8168 FETCH (UID 12178 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8169 FETCH (UID 12180 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8170 FETCH (UID 12182 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8171 FETCH (UID 12183 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8172 FETCH (UID 12184 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8173 FETCH (UID 12185 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8174 FETCH (UID 12186 FLAGS ())
IMAP: 17:24:13 [rx] * 8175 FETCH (UID 12187 FLAGS ())
IMAP: 17:24:13 [rx] * 8176 FETCH (UID 12188 FLAGS ())
IMAP: 17:24:13 [rx] * 8177 FETCH (UID 12190 FLAGS ())
IMAP: 17:24:13 [rx] * 8178 FETCH (UID 12191 FLAGS ())
IMAP: 17:24:13 [rx] * 8179 FETCH (UID 12192 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8180 FETCH (UID 12194 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8181 FETCH (UID 12195 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8182 FETCH (UID 12196 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8183 FETCH (UID 12198 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8184 FETCH (UID 12201 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8185 FETCH (UID 12202 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8186 FETCH (UID 12203 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8187 FETCH (UID 12206 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8188 FETCH (UID 12207 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8189 FETCH (UID 12208 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8190 FETCH (UID 12209 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8191 FETCH (UID 12210 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8192 FETCH (UID 12212 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8193 FETCH (UID 12213 FLAGS ())
IMAP: 17:24:13 [rx] * 8194 FETCH (UID 12215 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8195 FETCH (UID 12216 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8196 FETCH (UID 12217 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8197 FETCH (UID 12219 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8198 FETCH (UID 12220 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8199 FETCH (UID 12221 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8200 FETCH (UID 12222 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8201 FETCH (UID 12223 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8202 FETCH (UID 12224 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8203 FETCH (UID 12225 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8204 FETCH (UID 12226 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8205 FETCH (UID 12227 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8206 FETCH (UID 12229 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8207 FETCH (UID 12230 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8208 FETCH (UID 12231 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8209 FETCH (UID 12232 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8210 FETCH (UID 12233 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8211 FETCH (UID 12234 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8212 FETCH (UID 12235 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8213 FETCH (UID 12236 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8214 FETCH (UID 12243 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8215 FETCH (UID 12245 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8216 FETCH (UID 12246 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8217 FETCH (UID 12253 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8218 FETCH (UID 12254 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8219 FETCH (UID 12255 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8220 FETCH (UID 12257 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8221 FETCH (UID 12260 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8222 FETCH (UID 12261 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8223 FETCH (UID 12263 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8224 FETCH (UID 12264 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8225 FETCH (UID 12265 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8226 FETCH (UID 12266 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8227 FETCH (UID 12267 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8228 FETCH (UID 12269 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8229 FETCH (UID 12272 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8230 FETCH (UID 12273 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8231 FETCH (UID 12274 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8232 FETCH (UID 12275 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8233 FETCH (UID 12276 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8234 FETCH (UID 12277 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8235 FETCH (UID 12278 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8236 FETCH (UID 12279 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8237 FETCH (UID 12280 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8238 FETCH (UID 12281 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8239 FETCH (UID 12283 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8240 FETCH (UID 12285 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8241 FETCH (UID 12286 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8242 FETCH (UID 12288 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8243 FETCH (UID 12289 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8244 FETCH (UID 12290 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8245 FETCH (UID 12291 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8246 FETCH (UID 12293 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8247 FETCH (UID 12295 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8248 FETCH (UID 12296 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8249 FETCH (UID 12297 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8250 FETCH (UID 12298 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8251 FETCH (UID 12299 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8252 FETCH (UID 12302 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8253 FETCH (UID 12305 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8254 FETCH (UID 12306 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8255 FETCH (UID 12307 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8256 FETCH (UID 12308 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8257 FETCH (UID 12309 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8258 FETCH (UID 12310 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8259 FETCH (UID 12311 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8260 FETCH (UID 12312 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8261 FETCH (UID 12313 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8262 FETCH (UID 12315 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8263 FETCH (UID 12316 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8264 FETCH (UID 12317 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8265 FETCH (UID 12318 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8266 FETCH (UID 12319 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8267 FETCH (UID 12320 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8268 FETCH (UID 12322 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8269 FETCH (UID 12323 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8270 FETCH (UID 12324 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8271 FETCH (UID 12325 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8272 FETCH (UID 12326 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8273 FETCH (UID 12329 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8274 FETCH (UID 12330 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8275 FETCH (UID 12331 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8276 FETCH (UID 12332 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8277 FETCH (UID 12335 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8278 FETCH (UID 12336 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8279 FETCH (UID 12337 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8280 FETCH (UID 12338 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8281 FETCH (UID 12339 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8282 FETCH (UID 12340 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8283 FETCH (UID 12341 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8284 FETCH (UID 12342 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8285 FETCH (UID 12343 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8286 FETCH (UID 12344 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8287 FETCH (UID 12346 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8288 FETCH (UID 12347 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8289 FETCH (UID 12348 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8290 FETCH (UID 12349 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8291 FETCH (UID 12354 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8292 FETCH (UID 12355 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8293 FETCH (UID 12356 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8294 FETCH (UID 12358 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8295 FETCH (UID 12359 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8296 FETCH (UID 12360 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8297 FETCH (UID 12362 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8298 FETCH (UID 12367 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8299 FETCH (UID 12368 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8300 FETCH (UID 12369 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8301 FETCH (UID 12370 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8302 FETCH (UID 12371 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8303 FETCH (UID 12373 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8304 FETCH (UID 12374 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8305 FETCH (UID 12375 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8306 FETCH (UID 12376 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8307 FETCH (UID 12377 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8308 FETCH (UID 12378 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8309 FETCH (UID 12379 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8310 FETCH (UID 12380 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8311 FETCH (UID 12381 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8312 FETCH (UID 12382 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8313 FETCH (UID 12383 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8314 FETCH (UID 12384 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8315 FETCH (UID 12387 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8316 FETCH (UID 12388 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8317 FETCH (UID 12389 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8318 FETCH (UID 12390 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8319 FETCH (UID 12391 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8320 FETCH (UID 12394 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8321 FETCH (UID 12395 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8322 FETCH (UID 12396 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8323 FETCH (UID 12397 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8324 FETCH (UID 12400 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8325 FETCH (UID 12402 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8326 FETCH (UID 12405 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8327 FETCH (UID 12406 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8328 FETCH (UID 12407 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8329 FETCH (UID 12408 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8330 FETCH (UID 12409 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8331 FETCH (UID 12410 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8332 FETCH (UID 12411 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8333 FETCH (UID 12412 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8334 FETCH (UID 12415 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8335 FETCH (UID 12416 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8336 FETCH (UID 12418 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8337 FETCH (UID 12419 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8338 FETCH (UID 12423 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8339 FETCH (UID 12424 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8340 FETCH (UID 12425 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8341 FETCH (UID 12427 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8342 FETCH (UID 12429 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8343 FETCH (UID 12430 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8344 FETCH (UID 12431 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8345 FETCH (UID 12436 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8346 FETCH (UID 12438 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8347 FETCH (UID 12444 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8348 FETCH (UID 12447 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8349 FETCH (UID 12449 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8350 FETCH (UID 12452 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8351 FETCH (UID 12454 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8352 FETCH (UID 12459 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8353 FETCH (UID 12460 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8354 FETCH (UID 12461 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8355 FETCH (UID 12463 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8356 FETCH (UID 12464 FLAGS ())
IMAP: 17:24:13 [rx] * 8357 FETCH (UID 12465 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8358 FETCH (UID 12470 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8359 FETCH (UID 12473 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8360 FETCH (UID 12477 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8361 FETCH (UID 12478 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8362 FETCH (UID 12479 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8363 FETCH (UID 12480 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8364 FETCH (UID 12481 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8365 FETCH (UID 12482 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8366 FETCH (UID 12483 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8367 FETCH (UID 12485 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8368 FETCH (UID 12486 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8369 FETCH (UID 12487 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8370 FETCH (UID 12488 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8371 FETCH (UID 12490 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8372 FETCH (UID 12492 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8373 FETCH (UID 12493 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8374 FETCH (UID 12494 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8375 FETCH (UID 12495 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8376 FETCH (UID 12496 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8377 FETCH (UID 12497 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8378 FETCH (UID 12498 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8379 FETCH (UID 12502 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8380 FETCH (UID 12503 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8381 FETCH (UID 12504 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8382 FETCH (UID 12505 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8383 FETCH (UID 12506 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8384 FETCH (UID 12507 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8385 FETCH (UID 12508 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8386 FETCH (UID 12509 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8387 FETCH (UID 12511 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8388 FETCH (UID 12512 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8389 FETCH (UID 12513 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8390 FETCH (UID 12515 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8391 FETCH (UID 12516 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8392 FETCH (UID 12517 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8393 FETCH (UID 12518 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8394 FETCH (UID 12519 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8395 FETCH (UID 12520 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8396 FETCH (UID 12521 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8397 FETCH (UID 12522 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8398 FETCH (UID 12523 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8399 FETCH (UID 12524 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8400 FETCH (UID 12525 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8401 FETCH (UID 12526 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8402 FETCH (UID 12527 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8403 FETCH (UID 12528 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8404 FETCH (UID 12529 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8405 FETCH (UID 12530 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8406 FETCH (UID 12531 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8407 FETCH (UID 12532 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8408 FETCH (UID 12533 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8409 FETCH (UID 12534 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8410 FETCH (UID 12535 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8411 FETCH (UID 12536 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8412 FETCH (UID 12537 FLAGS (\Seen))
IMAP: 17:24:13 [rx] * 8413 FETCH (UID 12538 FLAGS (\Seen))
IMAP: 17:24:14 [db] OnNotify: asOld = 5, asNew = 5, ae = 3
IMAP: 17:24:14 [rx] * 8414 FETCH (UID 12539 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8415 FETCH (UID 12540 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8416 FETCH (UID 12541 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8417 FETCH (UID 12542 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8418 FETCH (UID 12543 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8419 FETCH (UID 12544 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8420 FETCH (UID 12545 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8421 FETCH (UID 12546 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8422 FETCH (UID 12547 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8423 FETCH (UID 12548 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8424 FETCH (UID 12549 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8425 FETCH (UID 12550 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8426 FETCH (UID 12551 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8427 FETCH (UID 12552 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8428 FETCH (UID 12553 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8429 FETCH (UID 12554 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8430 FETCH (UID 12555 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8431 FETCH (UID 12556 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8432 FETCH (UID 12557 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8433 FETCH (UID 12558 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8434 FETCH (UID 12559 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8435 FETCH (UID 12560 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8436 FETCH (UID 12561 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8437 FETCH (UID 12562 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8438 FETCH (UID 12563 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8439 FETCH (UID 12564 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8440 FETCH (UID 12565 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8441 FETCH (UID 12566 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8442 FETCH (UID 12567 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8443 FETCH (UID 12568 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8444 FETCH (UID 12569 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8445 FETCH (UID 12570 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8446 FETCH (UID 12571 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8447 FETCH (UID 12572 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8448 FETCH (UID 12573 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8449 FETCH (UID 12574 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8450 FETCH (UID 12575 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8451 FETCH (UID 12576 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8452 FETCH (UID 12577 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8453 FETCH (UID 12578 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8454 FETCH (UID 12579 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8455 FETCH (UID 12580 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8456 FETCH (UID 12581 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8457 FETCH (UID 12582 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8458 FETCH (UID 12583 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8459 FETCH (UID 12584 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8460 FETCH (UID 12585 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8461 FETCH (UID 12586 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8462 FETCH (UID 12587 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8463 FETCH (UID 12588 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8464 FETCH (UID 12591 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8465 FETCH (UID 12596 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8466 FETCH (UID 12598 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8467 FETCH (UID 12599 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8468 FETCH (UID 12600 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8469 FETCH (UID 12601 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8470 FETCH (UID 12602 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8471 FETCH (UID 12603 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8472 FETCH (UID 12604 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8473 FETCH (UID 12605 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8474 FETCH (UID 12606 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8475 FETCH (UID 12607 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8476 FETCH (UID 12608 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8477 FETCH (UID 12609 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8478 FETCH (UID 12610 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8479 FETCH (UID 12611 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8480 FETCH (UID 12612 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8481 FETCH (UID 12613 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8482 FETCH (UID 12614 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8483 FETCH (UID 12615 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8484 FETCH (UID 12616 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8485 FETCH (UID 12617 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8486 FETCH (UID 12618 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8487 FETCH (UID 12619 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8488 FETCH (UID 12620 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8489 FETCH (UID 12621 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8490 FETCH (UID 12622 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8491 FETCH (UID 12623 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8492 FETCH (UID 12624 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8493 FETCH (UID 12625 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8494 FETCH (UID 12626 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8495 FETCH (UID 12627 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8496 FETCH (UID 12628 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8497 FETCH (UID 12630 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8498 FETCH (UID 12631 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8499 FETCH (UID 12632 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8500 FETCH (UID 12633 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8501 FETCH (UID 12634 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8502 FETCH (UID 12635 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8503 FETCH (UID 12636 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8504 FETCH (UID 12637 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8505 FETCH (UID 12638 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8506 FETCH (UID 12639 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 8507 FETCH (UID 12640 FLAGS (\Seen))
IMAP: 17:24:14 [rx] v67f OK FETCH completed
IMAP: 17:24:14 [tx] p2lz LIST “” “INBOX”
IMAP: 17:24:14 [rx] * LIST (\Noinferiors \HasNoChildren) “\” Inbox
IMAP: 17:24:14 [rx] p2lz OK LIST completed
IMAP: 17:24:14 [tx] 4tt4 LSUB “” “*”
IMAP: 17:24:14 [rx] * LSUB () “\” “Deleted Messages”
IMAP: 17:24:14 [rx] * LSUB () “\” “Sent Messages”
IMAP: 17:24:14 [rx] * LSUB () “\” “Junk E-mail”
IMAP: 17:24:14 [rx] * LSUB () “\” Notes
IMAP: 17:24:14 [rx] 4tt4 OK LSUB completed
IMAP: 17:24:14 [tx] 6qjt UID FETCH 10508:11937 (UID FLAGS)
IMAP: 17:24:14 [rx] * 7001 FETCH (UID 10508 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7002 FETCH (UID 10509 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7003 FETCH (UID 10510 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7004 FETCH (UID 10511 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7005 FETCH (UID 10512 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7006 FETCH (UID 10515 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7007 FETCH (UID 10525 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7008 FETCH (UID 10526 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7009 FETCH (UID 10527 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7010 FETCH (UID 10530 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7011 FETCH (UID 10531 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7012 FETCH (UID 10532 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7013 FETCH (UID 10533 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7014 FETCH (UID 10534 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7015 FETCH (UID 10535 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7016 FETCH (UID 10536 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7017 FETCH (UID 10537 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7018 FETCH (UID 10538 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7019 FETCH (UID 10539 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7020 FETCH (UID 10541 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7021 FETCH (UID 10544 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7022 FETCH (UID 10545 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7023 FETCH (UID 10546 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7024 FETCH (UID 10547 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7025 FETCH (UID 10548 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7026 FETCH (UID 10550 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7027 FETCH (UID 10551 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7028 FETCH (UID 10552 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7029 FETCH (UID 10554 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7030 FETCH (UID 10557 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7031 FETCH (UID 10559 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7032 FETCH (UID 10561 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7033 FETCH (UID 10564 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7034 FETCH (UID 10566 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7035 FETCH (UID 10567 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7036 FETCH (UID 10568 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7037 FETCH (UID 10569 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7038 FETCH (UID 10570 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7039 FETCH (UID 10575 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7040 FETCH (UID 10578 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7041 FETCH (UID 10581 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7042 FETCH (UID 10582 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7043 FETCH (UID 10583 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7044 FETCH (UID 10584 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7045 FETCH (UID 10585 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7046 FETCH (UID 10586 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7047 FETCH (UID 10587 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7048 FETCH (UID 10588 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7049 FETCH (UID 10589 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7050 FETCH (UID 10591 FLAGS ())
IMAP: 17:24:14 [rx] * 7051 FETCH (UID 10594 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7052 FETCH (UID 10595 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7053 FETCH (UID 10596 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7054 FETCH (UID 10597 FLAGS ())
IMAP: 17:24:14 [rx] * 7055 FETCH (UID 10598 FLAGS ())
IMAP: 17:24:14 [rx] * 7056 FETCH (UID 10599 FLAGS ())
IMAP: 17:24:14 [rx] * 7057 FETCH (UID 10602 FLAGS ())
IMAP: 17:24:14 [rx] * 7058 FETCH (UID 10603 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7059 FETCH (UID 10607 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7060 FETCH (UID 10608 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7061 FETCH (UID 10609 FLAGS ())
IMAP: 17:24:14 [rx] * 7062 FETCH (UID 10610 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7063 FETCH (UID 10611 FLAGS ())
IMAP: 17:24:14 [rx] * 7064 FETCH (UID 10612 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7065 FETCH (UID 10613 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7066 FETCH (UID 10614 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7067 FETCH (UID 10615 FLAGS ())
IMAP: 17:24:14 [rx] * 7068 FETCH (UID 10616 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7069 FETCH (UID 10617 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7070 FETCH (UID 10619 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7071 FETCH (UID 10620 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7072 FETCH (UID 10621 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7073 FETCH (UID 10622 FLAGS ())
IMAP: 17:24:14 [rx] * 7074 FETCH (UID 10623 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7075 FETCH (UID 10624 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7076 FETCH (UID 10625 FLAGS ())
IMAP: 17:24:14 [rx] * 7077 FETCH (UID 10626 FLAGS ())
IMAP: 17:24:14 [rx] * 7078 FETCH (UID 10627 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7079 FETCH (UID 10628 FLAGS ())
IMAP: 17:24:14 [rx] * 7080 FETCH (UID 10629 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7081 FETCH (UID 10630 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7082 FETCH (UID 10631 FLAGS ())
IMAP: 17:24:14 [rx] * 7083 FETCH (UID 10632 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7084 FETCH (UID 10634 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7085 FETCH (UID 10637 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7086 FETCH (UID 10638 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7087 FETCH (UID 10639 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7088 FETCH (UID 10640 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7089 FETCH (UID 10641 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7090 FETCH (UID 10642 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7091 FETCH (UID 10644 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7092 FETCH (UID 10645 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7093 FETCH (UID 10646 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7094 FETCH (UID 10647 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7095 FETCH (UID 10651 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7096 FETCH (UID 10652 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7097 FETCH (UID 10653 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7098 FETCH (UID 10655 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7099 FETCH (UID 10656 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7100 FETCH (UID 10657 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7101 FETCH (UID 10658 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7102 FETCH (UID 10659 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7103 FETCH (UID 10661 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7104 FETCH (UID 10664 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7105 FETCH (UID 10666 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7106 FETCH (UID 10667 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7107 FETCH (UID 10668 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7108 FETCH (UID 10669 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7109 FETCH (UID 10670 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7110 FETCH (UID 10672 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7111 FETCH (UID 10673 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7112 FETCH (UID 10674 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7113 FETCH (UID 10675 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7114 FETCH (UID 10676 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7115 FETCH (UID 10677 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7116 FETCH (UID 10680 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7117 FETCH (UID 10681 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7118 FETCH (UID 10682 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7119 FETCH (UID 10686 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7120 FETCH (UID 10688 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7121 FETCH (UID 10689 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7122 FETCH (UID 10690 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7123 FETCH (UID 10691 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7124 FETCH (UID 10692 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7125 FETCH (UID 10694 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7126 FETCH (UID 10695 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7127 FETCH (UID 10698 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7128 FETCH (UID 10699 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7129 FETCH (UID 10700 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7130 FETCH (UID 10701 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7131 FETCH (UID 10702 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7132 FETCH (UID 10703 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7133 FETCH (UID 10705 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7134 FETCH (UID 10707 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7135 FETCH (UID 10708 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7136 FETCH (UID 10709 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7137 FETCH (UID 10710 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7138 FETCH (UID 10711 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7139 FETCH (UID 10712 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7140 FETCH (UID 10713 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7141 FETCH (UID 10714 FLAGS ())
IMAP: 17:24:14 [rx] * 7142 FETCH (UID 10716 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7143 FETCH (UID 10718 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7144 FETCH (UID 10719 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7145 FETCH (UID 10720 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7146 FETCH (UID 10721 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7147 FETCH (UID 10723 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7148 FETCH (UID 10724 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7149 FETCH (UID 10725 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7150 FETCH (UID 10728 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7151 FETCH (UID 10731 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7152 FETCH (UID 10734 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7153 FETCH (UID 10736 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7154 FETCH (UID 10737 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7155 FETCH (UID 10738 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7156 FETCH (UID 10740 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7157 FETCH (UID 10742 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7158 FETCH (UID 10748 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7159 FETCH (UID 10754 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7160 FETCH (UID 10755 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7161 FETCH (UID 10756 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7162 FETCH (UID 10757 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7163 FETCH (UID 10758 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7164 FETCH (UID 10759 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7165 FETCH (UID 10760 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7166 FETCH (UID 10761 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7167 FETCH (UID 10762 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7168 FETCH (UID 10763 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7169 FETCH (UID 10764 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7170 FETCH (UID 10766 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7171 FETCH (UID 10767 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7172 FETCH (UID 10768 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7173 FETCH (UID 10769 FLAGS ())
IMAP: 17:24:14 [rx] * 7174 FETCH (UID 10771 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7175 FETCH (UID 10772 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7176 FETCH (UID 10773 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7177 FETCH (UID 10777 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7178 FETCH (UID 10778 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7179 FETCH (UID 10784 FLAGS ())
IMAP: 17:24:14 [rx] * 7180 FETCH (UID 10785 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7181 FETCH (UID 10786 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7182 FETCH (UID 10787 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7183 FETCH (UID 10788 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7184 FETCH (UID 10789 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7185 FETCH (UID 10790 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7186 FETCH (UID 10792 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7187 FETCH (UID 10795 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7188 FETCH (UID 10798 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7189 FETCH (UID 10799 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7190 FETCH (UID 10801 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7191 FETCH (UID 10802 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7192 FETCH (UID 10803 FLAGS ())
IMAP: 17:24:14 [rx] * 7193 FETCH (UID 10804 FLAGS ())
IMAP: 17:24:14 [rx] * 7194 FETCH (UID 10805 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7195 FETCH (UID 10806 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7196 FETCH (UID 10807 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7197 FETCH (UID 10808 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7198 FETCH (UID 10809 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7199 FETCH (UID 10810 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7200 FETCH (UID 10811 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7201 FETCH (UID 10812 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7202 FETCH (UID 10813 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7203 FETCH (UID 10814 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7204 FETCH (UID 10815 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7205 FETCH (UID 10816 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7206 FETCH (UID 10817 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7207 FETCH (UID 10818 FLAGS (\Seen))
IMAP: 17:24:14 [rx] * 7208 FETCH (UID 10819 FLAGS ())
IMAP: 17:24:14 [rx] * 7209 FETCH (UID 10820 FLAGS ())
IMAP: 17:24:15 [db] OnNotify: asOld = 5, asNew = 5, ae = 3
IMAP: 17:24:15 [rx] * 7210 FETCH (UID 10821 FLAGS ())
IMAP: 17:24:15 [rx] * 7211 FETCH (UID 10822 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7212 FETCH (UID 10825 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7213 FETCH (UID 10827 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7214 FETCH (UID 10828 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7215 FETCH (UID 10829 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7216 FETCH (UID 10830 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7217 FETCH (UID 10831 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7218 FETCH (UID 10832 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7219 FETCH (UID 10833 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7220 FETCH (UID 10834 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7221 FETCH (UID 10835 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7222 FETCH (UID 10836 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7223 FETCH (UID 10838 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7224 FETCH (UID 10839 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7225 FETCH (UID 10841 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7226 FETCH (UID 10842 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7227 FETCH (UID 10843 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7228 FETCH (UID 10844 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7229 FETCH (UID 10845 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7230 FETCH (UID 10847 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7231 FETCH (UID 10849 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7232 FETCH (UID 10850 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7233 FETCH (UID 10851 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7234 FETCH (UID 10852 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7235 FETCH (UID 10853 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7236 FETCH (UID 10854 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7237 FETCH (UID 10855 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7238 FETCH (UID 10856 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7239 FETCH (UID 10857 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7240 FETCH (UID 10861 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7241 FETCH (UID 10862 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7242 FETCH (UID 10863 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7243 FETCH (UID 10865 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7244 FETCH (UID 10866 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7245 FETCH (UID 10867 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7246 FETCH (UID 10869 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7247 FETCH (UID 10870 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7248 FETCH (UID 10872 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7249 FETCH (UID 10873 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7250 FETCH (UID 10874 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7251 FETCH (UID 10875 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7252 FETCH (UID 10877 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7253 FETCH (UID 10878 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7254 FETCH (UID 10879 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7255 FETCH (UID 10880 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7256 FETCH (UID 10881 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7257 FETCH (UID 10883 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7258 FETCH (UID 10884 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7259 FETCH (UID 10885 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7260 FETCH (UID 10888 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7261 FETCH (UID 10889 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7262 FETCH (UID 10890 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7263 FETCH (UID 10891 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7264 FETCH (UID 10892 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7265 FETCH (UID 10893 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7266 FETCH (UID 10894 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7267 FETCH (UID 10895 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7268 FETCH (UID 10897 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7269 FETCH (UID 10899 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7270 FETCH (UID 10900 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7271 FETCH (UID 10902 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7272 FETCH (UID 10903 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7273 FETCH (UID 10904 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7274 FETCH (UID 10905 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7275 FETCH (UID 10907 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7276 FETCH (UID 10908 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7277 FETCH (UID 10909 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7278 FETCH (UID 10911 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7279 FETCH (UID 10918 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7280 FETCH (UID 10919 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7281 FETCH (UID 10920 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7282 FETCH (UID 10922 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7283 FETCH (UID 10923 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7284 FETCH (UID 10924 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7285 FETCH (UID 10925 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7286 FETCH (UID 10926 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7287 FETCH (UID 10927 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7288 FETCH (UID 10929 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7289 FETCH (UID 10930 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7290 FETCH (UID 10939 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7291 FETCH (UID 10940 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7292 FETCH (UID 10941 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7293 FETCH (UID 10942 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7294 FETCH (UID 10943 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7295 FETCH (UID 10944 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7296 FETCH (UID 10948 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7297 FETCH (UID 10949 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7298 FETCH (UID 10950 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7299 FETCH (UID 10951 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7300 FETCH (UID 10952 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7301 FETCH (UID 10953 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7302 FETCH (UID 10955 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7303 FETCH (UID 10956 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7304 FETCH (UID 10957 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7305 FETCH (UID 10958 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7306 FETCH (UID 10959 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7307 FETCH (UID 10960 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7308 FETCH (UID 10961 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7309 FETCH (UID 10962 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7310 FETCH (UID 10963 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7311 FETCH (UID 10964 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7312 FETCH (UID 10965 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7313 FETCH (UID 10967 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7314 FETCH (UID 10970 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7315 FETCH (UID 10971 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7316 FETCH (UID 10972 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7317 FETCH (UID 10973 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7318 FETCH (UID 10977 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7319 FETCH (UID 10979 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7320 FETCH (UID 10981 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7321 FETCH (UID 10984 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7322 FETCH (UID 10987 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7323 FETCH (UID 10988 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7324 FETCH (UID 10989 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7325 FETCH (UID 10990 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7326 FETCH (UID 10991 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7327 FETCH (UID 10992 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7328 FETCH (UID 10993 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7329 FETCH (UID 10994 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7330 FETCH (UID 10995 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7331 FETCH (UID 10996 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7332 FETCH (UID 10997 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7333 FETCH (UID 11003 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7334 FETCH (UID 11004 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7335 FETCH (UID 11006 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7336 FETCH (UID 11007 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7337 FETCH (UID 11008 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7338 FETCH (UID 11009 FLAGS ())
IMAP: 17:24:15 [rx] * 7339 FETCH (UID 11010 FLAGS ())
IMAP: 17:24:15 [rx] * 7340 FETCH (UID 11011 FLAGS ())
IMAP: 17:24:15 [rx] * 7341 FETCH (UID 11012 FLAGS ())
IMAP: 17:24:15 [rx] * 7342 FETCH (UID 11015 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7343 FETCH (UID 11018 FLAGS ())
IMAP: 17:24:15 [rx] * 7344 FETCH (UID 11019 FLAGS ())
IMAP: 17:24:15 [rx] * 7345 FETCH (UID 11020 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7346 FETCH (UID 11021 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7347 FETCH (UID 11022 FLAGS ())
IMAP: 17:24:15 [rx] * 7348 FETCH (UID 11023 FLAGS ())
IMAP: 17:24:15 [rx] * 7349 FETCH (UID 11024 FLAGS ())
IMAP: 17:24:15 [rx] * 7350 FETCH (UID 11025 FLAGS ())
IMAP: 17:24:15 [rx] * 7351 FETCH (UID 11026 FLAGS ())
IMAP: 17:24:15 [rx] * 7352 FETCH (UID 11028 FLAGS ())
IMAP: 17:24:15 [rx] * 7353 FETCH (UID 11029 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7354 FETCH (UID 11030 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7355 FETCH (UID 11031 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7356 FETCH (UID 11033 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7357 FETCH (UID 11035 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7358 FETCH (UID 11036 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7359 FETCH (UID 11037 FLAGS ())
IMAP: 17:24:15 [rx] * 7360 FETCH (UID 11039 FLAGS ())
IMAP: 17:24:15 [rx] * 7361 FETCH (UID 11040 FLAGS ())
IMAP: 17:24:15 [rx] * 7362 FETCH (UID 11041 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7363 FETCH (UID 11042 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7364 FETCH (UID 11043 FLAGS ())
IMAP: 17:24:15 [rx] * 7365 FETCH (UID 11044 FLAGS ())
IMAP: 17:24:15 [rx] * 7366 FETCH (UID 11045 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7367 FETCH (UID 11046 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7368 FETCH (UID 11047 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7369 FETCH (UID 11048 FLAGS ())
IMAP: 17:24:15 [rx] * 7370 FETCH (UID 11049 FLAGS ())
IMAP: 17:24:15 [rx] * 7371 FETCH (UID 11050 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7372 FETCH (UID 11052 FLAGS ())
IMAP: 17:24:15 [rx] * 7373 FETCH (UID 11053 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7374 FETCH (UID 11054 FLAGS ())
IMAP: 17:24:15 [rx] * 7375 FETCH (UID 11055 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7376 FETCH (UID 11056 FLAGS ())
IMAP: 17:24:15 [rx] * 7377 FETCH (UID 11057 FLAGS ())
IMAP: 17:24:15 [rx] * 7378 FETCH (UID 11058 FLAGS ())
IMAP: 17:24:15 [rx] * 7379 FETCH (UID 11059 FLAGS ())
IMAP: 17:24:15 [rx] * 7380 FETCH (UID 11060 FLAGS ())
IMAP: 17:24:15 [rx] * 7381 FETCH (UID 11061 FLAGS ())
IMAP: 17:24:15 [rx] * 7382 FETCH (UID 11062 FLAGS ())
IMAP: 17:24:15 [rx] * 7383 FETCH (UID 11065 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7384 FETCH (UID 11066 FLAGS ())
IMAP: 17:24:15 [rx] * 7385 FETCH (UID 11067 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7386 FETCH (UID 11068 FLAGS ())
IMAP: 17:24:15 [rx] * 7387 FETCH (UID 11070 FLAGS ())
IMAP: 17:24:15 [rx] * 7388 FETCH (UID 11072 FLAGS ())
IMAP: 17:24:15 [rx] * 7389 FETCH (UID 11074 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7390 FETCH (UID 11075 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7391 FETCH (UID 11076 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7392 FETCH (UID 11079 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7393 FETCH (UID 11080 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7394 FETCH (UID 11081 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7395 FETCH (UID 11085 FLAGS ())
IMAP: 17:24:15 [rx] * 7396 FETCH (UID 11086 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7397 FETCH (UID 11088 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7398 FETCH (UID 11089 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7399 FETCH (UID 11090 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7400 FETCH (UID 11091 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7401 FETCH (UID 11092 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7402 FETCH (UID 11093 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7403 FETCH (UID 11094 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7404 FETCH (UID 11096 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7405 FETCH (UID 11097 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7406 FETCH (UID 11098 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7407 FETCH (UID 11099 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7408 FETCH (UID 11100 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7409 FETCH (UID 11101 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7410 FETCH (UID 11102 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7411 FETCH (UID 11103 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7412 FETCH (UID 11104 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7413 FETCH (UID 11105 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7414 FETCH (UID 11108 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7415 FETCH (UID 11110 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7416 FETCH (UID 11111 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7417 FETCH (UID 11113 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7418 FETCH (UID 11114 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7419 FETCH (UID 11115 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7420 FETCH (UID 11116 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7421 FETCH (UID 11117 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7422 FETCH (UID 11118 FLAGS ())
IMAP: 17:24:15 [rx] * 7423 FETCH (UID 11121 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7424 FETCH (UID 11122 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7425 FETCH (UID 11123 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7426 FETCH (UID 11124 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7427 FETCH (UID 11125 FLAGS (\Seen))
IMAP: 17:24:15 [rx] * 7428 FETCH (UID 11126 FLAGS (\Seen))
IMAP: 17:24:15 [
ms outllok sudden stop to get email from imap server and when we reconfigure outlook then again mail start coming…
do you have problems with outlook or em client? Log you have sent does not looks like em client’s.
Jan
Just experienced the same problem. I have been using eM Client (paid version 5.0) on my home computer and work computer for six months without encountering this problem; but this morning it suddenly occurred on my home computer. However, it has NOT affected the work computer. Very strange. Like Greg, it is only happening with my Rackspace email account, not my Gmail account. I tried Greg’s idea of changing to the non-secure setting on port 143, and finally my emails downloaded. So, all’s well for now; but why would this suddenly happen, and why can’t I have secure email? It’s concerning…
Hi, these are the logs from MS outlook. and backend IMAP server is Lotus Domino(IBM)…
We are still tracking if this problem is with ms outlook or with server…, when this problem occur then telnet and ping properly comes…but mail’s not downloaded
they could have changed something on the server with authentication, we have not changed anything in eM Client about this so it has to be on their side.
Jan
Okay. I will try Rackspace tech support and post back here if they have anything useful to tell me.
can I ask if they have answered?
Jan
Hi since I have upgraded my email client from 6 to 7 and within the last few weeks I have an annoying problem with emclient 's IMAP error reads:
“An attempt to connect to…(email addy ) failed. This could be caused by a temporary server inability or incorrect settings. Do you want to check the settings?”
It does connect though because the emails do come in … I check the settings but I think I will check on att.net for imap settings … what else can I do to stop this annoying message?
Hi All,
I have same issue as Katie. I am a newbie emClient user, with only IMAP Gmail account set in emClient. As I use it on my notebook and I travel to customers on daily basis, each time I wake my notebook from sleep, before I get connected to network, same annoying message pops up.
I then must click to ignore it. In few moments, emClient connects without problems.
Is there some possibility to configure emClient same way as MS Outlook, which has in these situations only popup in notification areas "connection to <> lost / connection to <> restored"
Thanks a lot
Stan
I’m getting the same message as Kathie & Stan. This is getting very old. This is happening with my Gmail account only. Need answers.
T.W.
Same IMAP error as Kathie all day. Starts to be annoying. Please fix this, thanks! (Windows Email works perfectly in the same machine)
I, too, am having the same issue with regular the “failure to connect” message with my accounts. I have eM on my home computer with an Outlook and a Gmail account. My work computer has that same Outlook account and an InMotion account. This failure occurs on the Outlook and InMotion regularly (dozens of times each day). The Gmail is fine.
This is getting ridiculous as I am missing work emails while at work. The location of my office makes cell coverage very weak and spotty (at times my phone cannot connect until I walk down the hall or get to another floor), so I cannot rely on my phone to tell me that a message has come. When I diagnose and the connection is tested, all is fine… every time.
I was thinking about paying for Pro so I can have all three accounts at both work and home, but if this is what I can expect, I might dump eM for something else. Can someone PLEASE assist? If this is " the best" email client on the market, there should be a fix.
Same problem since a week or two. IMAP problem to an internal server (I host my own) the moment I added a 5th account (I have the pro version).
Even sync trouble as some mail which I drag and dropped appeared double or tripple. Which does not show in emClient, but on my mobile and webbased I had to correct it.
I had the same problem with connection error messages, so I set it to not show the messages. However, the e-mails were slow to show up, either the received or sent ones. I then changed the IMAP setting to read POP3 instead of IMAP. This caused a red ! to appear next to the server name in the left hand column, but e-mails now show up more quickly in INBOX and SENT folders.
It may have been that your IMAP settings were incorrect. Also with some email accounts, only the Inbox is synced in real-time, and the other folders sync according to the interval you have set in eM Client settings.
The red ! indicates that eM Client has not been able to connect as expected to an IMAP account. Changing the IMAP settings to POP3 settings should not work with most servers, but this also means that if it does work, the folders will no longer be synced as you are now using POP3.
Could you maybe provide a screenshot of your account settings? Just the IMAP tab will do.
