I have recently moved my multiple email servers to FastMail and I am very happy with the result, but I am having a few problems with the integration between the two of them. I have seen in the forum that other people are using both, but I have not found the solution to my problems.
My setup at FastMail is that I manage 5 domains and I have around 20 aliases. I have automatic rules that place the incoming mail in a folder for each domain. When I compose new mail in the FastMail web app, I can select the alias to use and the external world sees that I am apparently sending my messages from the correct domain.
I want to replicate this behaviour on eM Client, but I have not found how to associate my aliases with the FastMail account, so I can only send email from eM Client using my generic FastMail address.
I have not found how to synchronize my Calendar and Contacts between FastMail and eM Client.
Iâm bit confused, can you not setup your aliases you want with your Fastmail account in eM Client accounts and not your generic aliases ?
Once you add the aliases you do want to your Fastmail account in eM Client via âMenu / Accounts / Generalâ tab, you then when composing, replying or forwarding mail select whatever Fastmail alias you require in the popout menu on the right of your Fastmail account.
(Setup Fastmail for eM Client Calendar and Contacts using âCaldav & Carddavâ).
If you select this option, you probably wonât have to manually setup any aliases because eM Client will automatically detect which alias the incoming message was sent to, and when you reply to that message, it will create the alias on-the-fly and use that.
It may not work in all scenarios, but give it a try.
Thank you for your message. Setting the aliases was easy enough. I had not noticed the âAliasesâŚâ button on the Accounts dialog.
For the other task, I had already seen the help page you mention, but it is for an older version of eM Client and I donât see how to link to Calendars and Contacts on the current v9.
I have been investigating further and I see that on my Accounts dialog, I do not have âCalDav/CardDavâ on the Services list. That explains why I cannot enter the address.
Is it possible to add these services without recreating the account?
That Caldav and Carddav Fastmail setup webpage article above should be exactly the same in any version of eM Client. Have you tried the below ?
For the Fastmail Calendar, when you go to âMenu / Accountsâ you click for adding the Calendar, âAdd accountâ and click âCalendarâ manually, and choose Caldav and follow the Fastmail Calendar setup instructions.
For the Fastmail Contacts, when you go to âMenu / Accountsâ you click for adding the Contacts, âAdd accountâ and click âContactsâ manually, and choose Carddav in eM Client and then follow the Fastmail Contacts setup instructions.
You are a life saver! I had not thought of adding new specialized accounts for the Calendar and Contacts services, maintaining the existing one for Email.
I have finally setup FastMail with eM Client thanks to your help.
