my em client tried to update but it fail to remove earliier version. What should I do? Just look the attached shot.
This can happen when you use some cleaner utility to clear space or optimize the Windows Registry on your device. Those files are needed by the Windows Installer Service, so it can install/uninstall/repair apps on the device, but these utilities delete the files and break the Windows Installer Service.
Please go to this page: Fix problems that block programs from being installed or removed - Microsoft Support
Follow the instructions to fix the issue. When that is done, try the eM Client install again.
Hi, Gary
You make me solve my problem. Thanks.
em client makes me tired to update and uninstall.
