I may have been dreaming this or using another application, but did EM Client used to have an option to insert a field from a contact record for the purposes of a mailshot?
Hello AJ,
I am not quite sure what you mean, but you can insert variables that might cover your needs.
Just right-click inside the body of a message, choose Insert>Variable and look under the Contact variables.
