Initial tab character in message body after pressing tab in subject?
Something that just started happening and I am not sure if I did something to cause it. I create a new email, enter the TO, tab to the subject and enter the subject. Then I tab to the body. And the body ends up with an initial tab in it – which I then have to delete since everything following is flush left.
Anybody have any thoughts or pointers on this?
This issue might be also relates to another thread with the latest version of eM Client V10.4.4867 where other users are experiencing similar problems. Hopefully the next update will fix this.
Yes. That sounds like it… Thanks! (always nice to know that you are not alone :slight_smile:
I tested a slightly later eM Client Interim release V10.4.4924 for Windows and Mac and that initial tab space issue in the message body appears to be resolved but “only in the Windows version”.
So i suspect an official release update won’t be far away with the fix in it for Windows and Mac.
The latest V10.4.5298 just updated on the release history page fixes this issue for Mac.
Great. Thanks for posting!
