The problem is no longer fixed by a repair. I use this for a .edu account and our faculty directory is rather large, so running this every 5 minutes is FRUSTRATING.
I am a paying PRO customer and concur with everyone else, em Client should be posting a permanent fix, not a 5 minute patch.
Harry
Hello Harry,
we are very sorry for the inconvenience, but it looks like there is something happening on the google servers again, and indeed, the repair solution won’t help permanently anymore, as the issue is currently not even fixed on the server side. Unfortunately, until it is, we can’t make our own fix either, since the situation on the server isn’t stable enough for us to find a solution.
I can suggest disabling the popups for now so you are not interrupted constantly and we will post to the forums when the issue has been resolved.
Best regards,
How can I disable them? Do not see it in Settings.
Hello Harry,
there is a new release with a solution to this problem now: http://www.emclient.com/dist/v6.0.23421/setup.msi
Please don’t hesitate to let us know if it you still experience this issue after installing this release.
Best regards,
