I’m working with Windows 10 (since 4 weeks) and eM Client version 6.0.23181
It worked very well together … until a few days ago I got on every start up the following bug:
eM Client (6.0.23181.0)Windows: Microsoft Windows NT 6.2.9200.0, Framework: 4.0.30319.42000
System.Data.SQLite.SQLiteException (0x80004005): constraint failed
constraint failed
bij System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
bij System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
bij System.Data.SQLite.SQLiteDataReader.NextResult()
bij System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
bij System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
bij System.Data.SQLite.SQLiteCommand.ExecuteScalar()
bij MailClient.Storage.Data.SQLite.DbContactRepository.Store(IContactRepositoryItem contact)
bij MailClient.Storage.Data.SQLite.DbRepository1.Add[ST](Object senderContext, IEnumerable
1 items, Action1 storeCallback) bij MailClient.Storage.Data.SQLite.DbRepository
1.Add[ST](Object senderContext, IEnumerable1 items) bij MailClient.Storage.Application.ItemCollection
2.AddRange(IEnumerable1 items) bij MailClient.Storage.Application.Contact.ContactItemCollection.AddRange(IEnumerable
1 items)
bij MailClient.Protocols.Common.ItemSynchronizeContext2.StoreItems(SynchronizationType synchronizationType, IEnumerable
1 newItems)
bij MailClient.Protocols.Common.ItemSynchronizeContext2.Synchronize[T](SynchronizationType synchronizationType, IEnumerable
1 items, Func2 getUniqueId, Func
3 hasChanged, Func2 isDeleted, Func
2 convertItems, Action2 updateItem) bij MailClient.Protocols.Gdata.ContactItemSynchronizer.Synchronize(IItemSynchronizeContext
1 synchronizeContext, Folder folder, CancellationToken cancellationToken)
bij MailClient.Protocols.Common.ItemSynchronizer2.\<\>c\_\_DisplayClass2e.\<\>c\_\_DisplayClass33.<enqueuesynchronize>b__2a(WorkerStatus status, CancellationToken cancellationToken)<br> bij MailClient.Protocols.Gdata.GenericGdataCommand.Execute(WorkerStatus status)<br> bij MailClient.Commands.Command.Process(WorkerStatus status)<br> bij MailClient.Commands.SynchronizationQueue.ThreadWorker(Object threadData)<br> bij System.Threading.ThreadHelper.ThreadStart_Context(Object state)<br> bij System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)<br> bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)<br> bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)<br> bij System.Threading.ThreadHelper.ThreadStart(Object obj)<br><br><br><report xmlns="<a href=" http:>" rel="nofollow">http://emclient.com/ns/report">;<br> <product><br> <name>eM Client</name><br> <version>6.0.23181.0</version><br> </product><br> <silent>false</silent><br> <environment><br> <osversion>Microsoft Windows NT 6.2.9200.0</osversion><br> <frameworkversion>4.0.30319.42000</frameworkversion><br> </environment><br> <exception><br> <type>System.Data.SQLite.SQLiteException</type><br> <message>constraint failed<br>constraint failed</message><br> <source>System.Data.SQLite</source><br> <stack><br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663598</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLite3</type><br> <name>Reset</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteStatement</type><br> <name>stmt</name><br> </parameter><br> </parameters><br> </method><br> <offset>83</offset><br> <nativeoffset>2d35a</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663597</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLite3</type><br> <name>Step</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteStatement</type><br> <name>stmt</name><br> </parameter><br> </parameters><br> </method><br> <offset>3c</offset><br> <nativeoffset>bb</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663982</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteDataReader</type><br> <name>NextResult</name><br> <parameters></parameters><br> </method><br> <offset>12f</offset><br> <nativeoffset>150</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663943</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteDataReader</type><br> <name>.ctor</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>cmd</name><br> </parameter><br> <parameter><br> <assembly>System.Data</assembly><br> <type>System.Data.CommandBehavior</type><br> <name>behave</name><br> </parameter><br> </parameters><br> </method><br> <offset>5d</offset><br> <nativeoffset>72</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663757</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>ExecuteReader</name><br> <parameters><br> <parameter><br> <assembly>System.Data</assembly><br> <type>System.Data.CommandBehavior</type><br> <name>behavior</name><br> </parameter><br> </parameters><br> </method><br> <offset>c</offset><br> <nativeoffset>26</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663761</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>ExecuteScalar</name><br> <parameters></parameters><br> </method><br> <offset>6</offset><br> <nativeoffset>21</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100685552</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.SQLite.DbContactRepository</type><br> <name>Store</name><br> <parameters><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.IContactRepositoryItem</type><br> <name>contact</name><br> </parameter><br> </parameters><br> </method><br> <offset>4de</offset><br> <nativeoffset>cc7</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100670223</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.SQLite.DbRepository
1
Add
MailClient
mscorlib
System.Object
senderContext
mscorlib
items
mscorlib
storeCallback
d5
244
MailClient.exe
100670222
MailClient
MailClient.Storage.Data.SQLite.DbRepository1</type><br> <name>Add</name><br> <genericarguments><br> <argument><br> <assembly>MailClient</assembly><br> <type></type><br> </argument><br> </genericarguments><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>senderContext</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type></type><br> <name>items</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>39</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100670037</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Application.ItemCollection
2
AddRange
mscorlib
items
15d
4ef
MailClient.exe
100677301
MailClient
AddRange
mscorlib
System.Collections.Generic.IEnumerable1[[MailClient.Storage.Application.Contact.ContactItem, MailClient, Version=6.0.23181.0, Culture=neutral, PublicKeyToken=null]]</type><br> <name>items</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>21</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100667548</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Protocols.Common.ItemSynchronizeContext
2
StoreItems
MailClient
MailClient.Protocols.Common.SynchronizationType
synchronizationType
mscorlib
newItems
e4
266
MailClient.exe
100667552
MailClient
MailClient.Protocols.Common.ItemSynchronizeContext2</type><br> <name>Synchronize</name><br> <genericarguments><br> <argument><br> <assembly>MailClient</assembly><br> <type></type><br> </argument><br> </genericarguments><br> <parameters><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.Protocols.Common.SynchronizationType</type><br> <name>synchronizationType</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type></type><br> <name>items</name><br> </parameter><br> <parameter><br> <assembly>LinqBridge</assembly><br> <type></type><br> <name>getUniqueId</name><br> </parameter><br> <parameter><br> <assembly>LinqBridge</assembly><br> <type></type><br> <name>hasChanged</name><br> </parameter><br> <parameter><br> <assembly>LinqBridge</assembly><br> <type></type><br> <name>isDeleted</name><br> </parameter><br> <parameter><br> <assembly>LinqBridge</assembly><br> <type></type><br> <name>convertItems</name><br> </parameter><br> <parameter><br> <assembly>LinqBridge</assembly><br> <type></type><br> <name>updateItem</name><br> </parameter><br> </parameters><br> </method><br> <offset>373</offset><br> <nativeoffset>8a9</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100668183</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Protocols.Gdata.ContactItemSynchronizer</type><br> <name>Synchronize</name><br> <parameters><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.Protocols.Common.IItemSynchronizeContext
synchronizeContext
MailClient
MailClient.Storage.Application.Folder
folder
MailClient
System.Threading.CancellationToken
cancellationToken
143
402
MailClient.exe
100698106
MailClient
MailClient.Protocols.Common.ItemSynchronizer`2+<>c DisplayClass2e+<>c DisplayClass33
<EnqueueSynchronize>b__2a
MailClient
MailClient.Commands.WorkerStatus
status
MailClient
cancellationToken
da
200
MailClient.exe
100668240
MailClient
Execute
MailClient
status
3e
af
MailClient.exe
100664033
MailClient
Process
MailClient
status
15
53
MailClient.exe
100664086
MailClient
ThreadWorker
mscorlib
System.Object
threadData
8c
11a
mscorlib.dll
100678214
mscorlib
ThreadStart_Context
mscorlib
System.Object
state
25
9c
mscorlib.dll
100677968
mscorlib
RunInternal
mscorlib
executionContext
mscorlib
System.Threading.ContextCallback
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
79
b3
mscorlib.dll
100677967
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
0
15
mscorlib.dll
100677966
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
2b
40
mscorlib.dll
100678215
mscorlib
ThreadStart
mscorlib
System.Object
obj
f
4d
183
MailClient.exe
C:\Program Files (x86)\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
6.0.23181.0
eM Client
eM Client
6.0.23181.0
False
False
False
False
False
Taalonafhankelijk
ntdll.dll
C:\WINDOWS\SYSTEM32\ntdll.dll
ntdll.dll
ntdll.dll.mui
10.0.10240.16384 (th1.150709-1700)
DLL-bestand voor NT-laag
Microsoft® Windows®-besturingssysteem
10.0.10240.16384
False
False
False
False
False
Nederlands (Nederland)
MSCOREE.DLL
C:\WINDOWS\SYSTEM32\MSCOREE.DLL
mscoree.dll
mscoree.dll
Microsoft .NET Runtime Execution Engine
Microsoft® Windows® Operating System
10.0.10240.16384
False
False
False
False
False
Engels (Verenigde Staten)
KERNEL32.dll
C:\WINDOWS\SYSTEM32\KERNEL32.dll
kernel32
kernel32
DLL-bestand voor Windows NT BASE API-client
Besturingssysteem Microsoft® Windows®
10.0.10240.16384
False
False
False
False
False
KERNELBASE.dll
C:\WINDOWS\SYSTEM32\KERNELBASE.dll
Kernelbase.dll
Kernelbase.dll.mui
10.0.10240.16384
False
False
False
False
False
ADVAPI32.dll
C:\WINDOWS\SYSTEM32\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
Geavanceerde Windows 32 basis-API
10.0.10240.16384
False
False
False
False
False
msvcrt.dll
C:\WINDOWS\SYSTEM32\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.10240.16384 (th1.150709-1700)
Windows NT CRT DLL
7.0.10240.16384
False
False
False
False
False
sechost.dll
C:\WINDOWS\SYSTEM32\sechost.dll
sechost.dll
sechost.dll.mui
Host for SCM/SDDL/LSA Lookup APIs
10.0.10240.16384
False
False
False
False
False
RPCRT4.dll
C:\WINDOWS\SYSTEM32\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
Runtime voor RPC (Remote Procedure Call)
10.0.10240.16384
False
False
False
False
False
SspiCli.dll
C:\WINDOWS\SYSTEM32\SspiCli.dll
security.dll
security.dll
Security Support Provider Interface
10.0.10240.16384
False
False
False
False
False
CRYPTBASE.dll
C:\WINDOWS\SYSTEM32\CRYPTBASE.dll
cryptbase.dll
cryptbase.dll
Base cryptographic API DLL
10.0.10240.16384
False
False
False
False
False
bcryptPrimitives.dll
C:\WINDOWS\SYSTEM32\bcryptPrimitives.dll
bcryptprimitives.dll
Windows Cryptographic Primitives Library
10.0.10240.16384
False
False
False
False
False
mscoreei.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
mscoreei.dll
mscoreei.dll
4.6.79.0 built by: NETFXREL2
Microsoft® .NET Framework
4.6.79.0
False
False
False
True
False
SHLWAPI.dll
C:\WINDOWS\SYSTEM32\SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL.MUI
Shell lichtgewicht hulpprogrammabibliotheek
10.0.10240.16384
False
False
False
False
False
combase.dll
C:\WINDOWS\SYSTEM32\combase.dll
COMBASE.DLL
COMBASE.DLL.MUI
Microsoft COM voor Windows
10.0.10240.16384
False
False
False
False
False
GDI32.dll
C:\WINDOWS\SYSTEM32\GDI32.dll
gdi32
gdi32
10.0.10240.16390 (th1_st1.150714-1601)
GDI Client DLL
10.0.10240.16390
False
False
False
False
False
USER32.dll
C:\WINDOWS\SYSTEM32\USER32.dll
user32
user32
DLL-bestand voor Windows USER API-client (meerdere gebruikers)
10.0.10240.16384
False
False
False
False
False
IMM32.DLL
C:\WINDOWS\SYSTEM32\IMM32.DLL
imm32
imm32
Multi-User Windows IMM32 API Client DLL
10.0.10240.16384
False
Fa
