System.TypeInitializationException: The type initializer for ‘System.Transactions.Diagnostics.DiagnosticTrace’ threw an exception. —> System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize —> System.Configuration.ConfigurationErrorsException: Unrecognized configuration section startup. (C:\Program Files (x86)\eM Client\DbRepair.exe.Config line 3) at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors()
at System.Configuration.ClientConfigurationSystem.EnsureInit(String configKey)
— End of inner exception stack trace —
at System.Configuration.ClientConfigurationSystem.PrepareClientConfigSystem(String sectionName)
at System.Configuration.ClientConfigurationSystem.System.Configuration.Internal.IInternalConfigSystem.GetSection(String sectionName)
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName)
at System.Diagnostics.DiagnosticsConfiguration.GetConfigSection()
at System.Diagnostics.DiagnosticsConfiguration.Initialize()
at System.Diagnostics.DiagnosticsConfiguration.get_Sources()
at System.Diagnostics.TraceSource.Initialize()
at System.Diagnostics.TraceSource.get_Switch()
at System.Transactions.Diagnostics.DiagnosticTrace…cctor()
at System.Transactions.Transaction.get_Current()
at System.Data.SQLite.SQLiteConnection.Open()
at DbRepair.DbTools.OpenConnection(String fileName)
at DbRepair.Form1.CheckCorruption()
at DbRepair.Form1.Check(Object state)
