Inbox should indicate if primary & other have messages
I suppose this is a feature request. In the Android app, at least, inboxes divided into two categories: “Primary” and “Other”. It would be nice to be able to see the counts of unread messages in each category so one would not have to switch back and forth to check. Perhaps put the count next to the category, such as the following:
Primary (2) Other (4)
If not, maybe there should be an option to have everything in one category.
Primary (2) Other (4)`
Go to “Menu / Settings / Mail / Categories” where you can enable to show Unread. The app then normally shows the unread messages next to each category.
If you “press and hold your finger” on a Category in the eM Client Droid or iOS app, it will bring up the “Settings / Category Tabs” section, where you can then eg: Disable the Other Category to then have all emails go in the Primary Inbox.
Thanks!
I never would have found the Category menu.
