Under Menu -Tools - do not appear the option Automatic Replies
This may help explain how “automatic replies” works in eMC.
" Once you set up the automatic reply as shown in the video tutorial the setting will be synchronized to the mail server, which will then take care of sending these replies while you’re away. We can provide automatic replies just for Exchange, Google and IceWarp accounts because the feature needs to be supported on the mail server to work as designed. So eM Client can replace any current exchange autoresponder software you might have used for your out of office messages.
If you do not have either of these accounts set up in eM Client, you will not see the option “Automatic Replies” under the “Tools” menu."
