Hi Andre, apparently you’re trying to perform backup while having the backup storage set to your installation folder, that’s unfortunately forbidden, you most likely don’t have the write permission for this folder.
Change your backup sotrage in the application settings and try to perform backup again.
Paul
Now, this pop up apear ( 2 times in 30 minutes)
eM Client (6.0.21372.0)Windows: Microsoft Windows NT 6.2.9200.0, Framework: 4.0.30319.34209
System.Data.SQLite.SQLiteException (0x80004005): constraint failed
UNIQUE constraint failed: MailItems.id
à System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
à System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
à System.Data.SQLite.SQLiteDataReader.NextResult()
à System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
à System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
à System.Data.SQLite.SQLiteCommand.ExecuteScalar()
à MailClient.Storage.Data.SQLite.DbMailRepository.Store(IMailRepositoryItem mail)
à MailClient.Storage.Data.SQLite.DbRepository1.Add[ST](Object senderContext, IEnumerable
1 items, Action1 storeCallback) à MailClient.Storage.Data.SQLite.DbRepository
1.Add[ST](Object senderContext, IEnumerable1 items) à MailClient.Storage.Application.ItemCollection
2.AddRange(IEnumerable1 items) à MailClient.Accounts.MailAccount.ReceiveCommand.receiveAccount\_receivedItem(Object sender, ItemEventArgs
1 items)
à MailClient.Pop3.Pop3ReceiveCommand.Execute(WorkerStatus status)
à MailClient.Commands.Command.Process(WorkerStatus status)
à MailClient.Commands.SynchronizationQueue.ThreadWorker(Object threadData)
à System.Threading.ThreadHelper.ThreadStart_Context(Object state)
à System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
à System.Threading.ThreadHelper.ThreadStart(Object obj)
" rel=“nofollow” target="_blank">http://emclient.com/ns/report ">; eM Client 6.0.21372.0 false Microsoft Windows NT 6.2.9200.0 4.0.30319.34209 System.Data.SQLite.SQLiteException constraint failed UNIQUE constraint failed: MailItems.id System.Data.SQLite
System.Data.SQLite.dll 100663598 System.Data.SQLite System.Data.SQLite.SQLite3 Reset System.Data.SQLite System.Data.SQLite.SQLiteStatement stmt 83 2c172
System.Data.SQLite.dll 100663597 System.Data.SQLite System.Data.SQLite.SQLite3 Step System.Data.SQLite System.Data.SQLite.SQLiteStatement stmt 3c bb
System.Data.SQLite.dll 100663982 System.Data.SQLite System.Data.SQLite.SQLiteDataReader NextResult 12f 150
System.Data.SQLite.dll 100663943 System.Data.SQLite System.Data.SQLite.SQLiteDataReader .ctor System.Data.SQLite System.Data.SQLite.SQLiteCommand cmd System.Data System.Data.CommandBehavior behave 5d 71
System.Data.SQLite.dll 100663757 System.Data.SQLite System.Data.SQLite.SQLiteCommand ExecuteReader System.Data System.Data.CommandBehavior behavior c 26
System.Data.SQLite.dll 100663761 System.Data.SQLite System.Data.SQLite.SQLiteCommand ExecuteScalar 6 21
MailClient.exe 100685719 MailClient MailClient.Storage.Data.SQLite.DbMailRepository Store MailClient MailClient.Storage.Data.IMailRepositoryItem mail 3df 952
MailClient.exe 100670338 MailClient MailClient.Storage.Data.SQLite.DbRepository1</type><br> <name>Add</name><br> <genericarguments><br> <argument><br> <assembly>MailClient</assembly><br> <type></type><br> </argument><br> </genericarguments><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>senderContext</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type></type><br> <name>items</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type></type><br> <name>storeCallback</name><br> </parameter><br> </parameters><br> </method><br> <offset>d5</offset><br> <nativeoffset>236</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100670337</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.SQLite.DbRepository
1 Add MailClient mscorlib System.Object senderContext mscorlib items 0 39
MailClient.exe 100670153 MailClient MailClient.Storage.Application.ItemCollection2</type><br> <name>AddRange</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type></type><br> <name>items</name><br> </parameter><br> </parameters><br> </method><br> <offset>15d</offset><br> <nativeoffset>4ef</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100687179</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Accounts.MailAccount+ReceiveCommand</type><br> <name>receiveAccount_receivedItem</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>sender</name><br> </parameter><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.ItemEventArgs
1[[MailClient.Storage.Application.Mail.MailItem, MailClient, Version=6.0.21372.0, Culture=neutral, PublicKeyToken=null]] items 0 3c
MailClient.exe 100690016 MailClient MailClient.Pop3.Pop3ReceiveCommand Execute MailClient MailClient.Commands.WorkerStatus status 61e d69
MailClient.exe 100664007 MailClient MailClient.Commands.Command Process MailClient MailClient.Commands.WorkerStatus status 15 53
MailClient.exe 100664060 MailClient MailClient.Commands.SynchronizationQueue ThreadWorker mscorlib System.Object threadData 8c 11a
mscorlib.dll 100669371 mscorlib System.Threading.ThreadHelper ThreadStart_Context mscorlib System.Object state 25 9b
mscorlib.dll 100668988 mscorlib System.Threading.ExecutionContext RunInternal mscorlib System.Threading.ExecutionContext executionContext mscorlib System.Threading.ContextCallback callback mscorlib System.Object state mscorlib System.Boolean preserveSyncCtx 70 a6
mscorlib.dll 100668987 mscorlib System.Threading.ExecutionContext Run mscorlib System.Threading.ExecutionContext executionContext mscorlib System.Threading.ContextCallback callback mscorlib System.Object state mscorlib System.Boolean preserveSyncCtx 0 15
mscorlib.dll 100668986 mscorlib System.Threading.ExecutionContext Run mscorlib System.Threading.ExecutionContext executionContext mscorlib System.Threading.ContextCallback callback mscorlib System.Object state 2b 40
mscorlib.dll 100669368 mscorlib System.Threading.ThreadHelper ThreadStart mscorlib System.Object obj f 4d 0 MailClient.exe C:\Program Files (x86)\eM Client\MailClient.exe MailClient.exe MailClient.exe 6.0.21372.0 eM Client eM Client 6.0.21372.0 False False False False False Langue neutre ntdll.dll C:\WINDOWS\SYSTEM32\ntdll.dll ntdll.dll ntdll.dll.mui 6.3.9600.17031 (winblue_gdr.140221-1952) DLL Couche NT Système d’exploitation Microsoft® Windows® 6.3.9600.17031 False False False False False Français (France) MSCOREE.DLL C:\WINDOWS\SYSTEM32\MSCOREE.DLL mscoree.dll mscoree.dll 6.3.9600.16384 (winblue_rtm.130821-1623) Microsoft .NET Runtime Execution Engine Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False Anglais (États-Unis) KERNEL32.dll C:\WINDOWS\SYSTEM32\KERNEL32.dll kernel32 kernel32 6.3.9600.17031 (winblue_gdr.140221-1952) DLL du client API BASE Windows NT Système d’exploitation Microsoft® Windows® 6.3.9600.17031 False False False False False Français (France) KERNELBASE.dll C:\WINDOWS\SYSTEM32\KERNELBASE.dll Kernelbase.dll Kernelbase.dll.mui 6.3.9600.17238 (winblue_gdr.140723-2018) DLL du client API BASE Windows NT Système d’exploitation Microsoft® Windows® 6.3.9600.17238 False False False False False Français (France) ADVAPI32.dll C:\WINDOWS\SYSTEM32\ADVAPI32.dll advapi32.dll advapi32.dll.mui 6.3.9600.16384 (winblue_rtm.130821-1623) API avancées Windows 32 Système d’exploitation Microsoft® Windows® 6.3.9600.16384 False False False False False Français (France) msvcrt.dll C:\WINDOWS\SYSTEM32\msvcrt.dll msvcrt.dll msvcrt.dll 7.0.9600.16384 (winblue_rtm.130821-1623) Windows NT CRT DLL Microsoft® Windows® Operating System 7.0.9600.16384 False False False False False Anglais (États-Unis) sechost.dll C:\WINDOWS\SYSTEM32\sechost.dll sechost.dll sechost.dll.mui 6.3.9600.16384 (winblue_rtm.130821-1623) Host for SCM/SDDL/LSA Lookup APIs Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False Anglais (États-Unis) RPCRT4.dll C:\WINDOWS\SYSTEM32\RPCRT4.dll rpcrt4.dll rpcrt4.dll.mui 6.3.9600.16384 (winblue_rtm.130821-1623) Runtime d’appel de procédure distante Système d’exploitation Microsoft® Windows® 6.3.9600.16384 False False False False False Français (France) SspiCli.dll C:\WINDOWS\SYSTEM32\SspiCli.dll security.dll security.dll 6.3.9600.16408 (winblue_gdr.130920-1803) Security Support Provider Interface Microsoft® Windows® Operating System 6.3.9600.16408 False False False False False Anglais (États-Unis) CRYPTBASE.dll C:\WINDOWS\SYSTEM32\CRYPTBASE.dll cryptbase.dll cryptbase.dll 6.3.9600.16384 (winblue_rtm.130821-1623) Base cryptographic API DLL Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False Anglais (États-Unis) bcryptPrimitives.dll C:\WINDOWS\SYSTEM32\bcryptPrimitives.dll bcryptprimitives.dll bcryptprimitives.dll 6.3.9600.17120 (winblue_gdr.140509-1516) Windows Cryptographic Primitives Library Microsoft® Windows® Operating System 6.3.9600.17120 False False False False False Anglais (États-Unis) mscoreei.dll C:\Windows\Microsoft.NET \Framework\v4.0.30319\mscoreei.dll mscoreei.dll mscoreei.dll 4.0.30319.34209 built by: FX452RTMGDR Microsoft .NET Runtime Execution Engine Microsoft® .NET Framework 4.0.30319.34209 False False False True False Anglais (États-Unis) SHLWAPI.dll C:\WINDOWS\SYSTEM32\SHLWAPI.dll SHLWAPI SHLWAPI.DLL.MUI 6.3.9600.16384 (winblue_rtm.130821-1623) Bibliothèque d’utilitaires légers du Shell Système d’exploitation Microsoft® Windows® 6.3.9600.16384 False False False False False Français (France) combase.dll C:\WINDOWS\SYSTEM32\combase.dll COMBASE.DLL COMBASE.DLL.MUI 6.3.9600.16384 (winblue_rtm.130821-1623) Microsoft COM pour Windows Système d’exploitation Microsoft® Windows® 6.3.9600.16384 False False False False False Français (France) USER32.dll C:\WINDOWS\SYSTEM32\USER32.dll user32 user32 6.3.9600.16384 (winblue_rtm.130821-1623) DLL client de l’API uilisateur de Windows multi-utilisateurs Système d’exploitation Microsoft® Windows® 6.3.9600.16384 False False False False False Français (France) GDI32.dll C:\WINDOWS\SYSTEM32\GDI32.dll gdi32 gdi32 6.3.9600.17246 (winblue_gdr.140801-1518) GDI Client DLL Microsoft® Windows® Operating System 6.3.9600.17246 False False False False False Anglais (États-Unis) IMM32.DLL C:\WINDOWS\system32\IMM32.DLL imm32 imm32 6.3.9600.17031 (winblue_gdr.140221-1952) Multi-User Windows IMM32 API Client DLL Microsoft® Windows® Operating System 6.3.9600.17031 False False False False False Anglais (États-Unis) MSCTF.dll C:\WINDOWS\SYSTEM32\MSCTF.dll MSCTF MSCTF.DLL.MUI 6.3.9600.16384 (winblue_rtm.130821-1623) DLL de MSCTF Server Système d’exploitation Microsoft® Windows® 6.3.9600.16384 False False False False False Français (France) clr.dll C:\Windows\Microsoft.NET \Framework\v4.0.30319\clr.dll clr.dll clr.dll 4.0.30319.34209 built by: FX452RTMGDR Microsoft .NET Runtime Common Language Runtime - WorkStation Microsoft® .NET Framework 4.0.30319.34209 False False False True False Anglais (États-Unis) MSVCR120_CLR0400.dll C:\WINDOWS\SYSTEM32\MSVCR120_CLR0400.dll msvcr120_clr0400.dll msvcr120_clr0400.dll 12.00.51670.34230 built by: FX452RTMGDR Microsoft® C Runtime Library Microsoft® Visual Studio® 12 CTP 12.00.51670.34230 False False False False False Anglais (États-Unis) mscorlib.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\mscorlib\d03a3ddcd6a395878751c5e90fa16915\mscorlib.ni.dll mscorlib.dll mscorlib.dll 4.0.30319.34209 built by: FX452RTMGDR Microsoft Common Language Runtime Class Library Microsoft® .NET Framework 4.0.30319.34209 False False False True False Anglais (États-Unis) ole32.dll C:\WINDOWS\SYSTEM32\ole32.dll OLE32.DLL OLE32.DLL.MUI 6.3.9600.16384 (winblue_rtm.130821-1623) Microsoft OLE pour Windows Système d’exploitation Microsoft® Windows® 6.3.9600.16384 False False False False False Français (France) kernel.appcore.dll C:\WINDOWS\SYSTEM32\kernel.appcore.dll kernel.appcore.dll kernel.appcore.dll 6.3.9600.16384 (winblue_rtm.130821-1623) AppModel API Host Microsoft® Windows® Operating System 6.3.9600.16384 False False False False False Anglais (États-Unis) uxtheme.dll C:\WINDOWS\system32\uxtheme.dll UxTheme.dll UxTheme.dll.mui 6.3.9600.16384 (winblue_rtm.130821-1623) Bibliothèque de thèmes Ux Microsoft Système d’exploitation Microsoft® Windows® 6.3.9600.16384 False False False False False Français (France) System.ni.dll C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System\1a6b5095c4416a37f9ca4cf4436d1311\System.ni.dll System.dll System.dll 4.0.30319.34239 built by: FX452RTMGDR .NET Framework Microsoft® .NET Framework 4.0.30319.34239 False False False True False Anglais (États-Unis) CRYPTSP.dll C:\WINDOWS\SYSTEM32\CRYPTSP.dll cryptsp.dll cryptsp.dll 6.3.9600.16384 (winblue_rtm.130821-1623)
Hi again Andre, I’m afraid your database is corrupt at the moment and you have to remove the database from your App Data folder.
Before you do so try to run this utility one more time to make sure if the problem persists, http://www.emclient.com/tools/dbrepairrebuildall.exe
If your issues continue and you’re unable to load the database after running the dbrepair tool, please navigate to your App Data/Roaming folder and rename or remove the current eM Client folder.
Next time you open eM Client a new database should be created allowing you to re-setup your accounts, unfortunately any local data may be lost as the database is corrupt and no longer accessible for eM client.
Paul
