Okay I’ll try to explain in detail.
I create a signature using Edit source function. Here is how it looks like
Then I set up this signature to be my default signature:
I create a new message, input my own address in To field. The signature appears not clickable. If I open Edit source, this is what I see:
I send it like this. I don’t change anything in the contents. Here is what I get in my inbox:
As you can see, it came without HREF attribute. This means there is no link, and it can’t be clickable, under any client.
There is a workaround: when I create a message, I must choose my signature again from Signature menu, even though it was inserted automatically by default. When I do so, this is how it looks like (it’s clickable):
(Note that at this point, if I don’t send the message but save it as a draft, then the workaround has to be used again before sending, or else it will look exactly like the first example - without HREF attribute. Both in sent and inbox folders.)
After sending with such a workaround applied, here is what I get in my inbox:
In this case, even though it appears not clickable, the HREF attribute is present.
If I send such a message to a different client, e.g. Gmail, the link is clickable. This is what I want. But to achieve this, I have to:
- Choose my signature again every time I create a message.
- Choose my signature again every time I continue editing an old message from draft.
Which is not convenient.
As for why it’s not clickable in eM Client, I guess this is a whole different story, which deserves a separate discussion. I believe it should be clickable, like with any other client where such links are clickable. More points:
- You mentioned the eM’s “inability to open some links”. I can’t accept this statement because (1) regular http/mailto links are clickable, and (2) any link can be clickable in the editor, and it all works. This is not an inability, but a programmed behavior.
- Any security concerns about making some links not clickable are illogical because eM doesn’t block unsafe attachments. It just lets the user know about possible danger, which should have been used with clickable links too instead.
- Not providing even an option to enable the expected behavior (clickable links) is a problem.
My guess though, is that it’s still related, because it seems like a source of this problem: if you disable this filtering, both the receiver would get clickable links as expected, and I would see clickable links in my sent messages.
