Importing of Contacts from WLM
How do I import my Contacts, including “Groups” from Windows Live Mail to eM Client?
Hello Khalil,
You can import your data using the File>Import function of eM Client and Import from Windows Live Mail.
If that does not work, you will need to export your Contacts from WLM as either CSV file or VCF files and then use the import option for these.
This goes from local data though. If you have your contacts saved on your mail server, you should be able to synchronize those just by setting up your account.
We’re sorry for the inconvenience, we realize the import from WLM is currently not completely convenient. Version 7.1 should run the import smoothly.
Maurice
