I am trying to import my email accounts from Postbox but Postbox does not show in the import options in eMClient. Anyone got a solution?
You might want to confirm you are using the latest eM Client version. If not, you can download it here by clicking the latest version number at the top of:
Yes I’m using version 10.0.3530 so what would you advise?
You need to install the latest one in the Release History. See @lancealot’s link above.
PostBox import options are not in 10.0.x versions
The latest version is 10.1.4588.0 so wouldn’t this work then?
