I’ve participated in several threads on the forum, but now my own problem is confined to an IMAP issue. My latest situation, is that I can send emails (and they are being received), but any sent to me are not arriving. The continued error message is ‘server not responding’ SMTP is working fine, but when I try the fix option for IMAP, it doesn’t work.
I have checked IMAP settings (for Virgin Media) several times and they are correct and exactly the same as I am using for V7. I have tried upgrading and going back to V7 several times, but still no luck. I thought about removing V7 instead of upgrading and installing V8 from scratch, but was concerned that if I deleted the database I might lose critical data, so haven’t done that yet.
Any advice would be gratefully received. V7 is fine for my needs, but can I use that indefinitely?
