I’m work with Thunderbird portable and an import isn’t possible i case “account was not found” and a selection for a directory is not possible
Hi, can you please make a screenshot of this issue?
Are you trying to import accounts or folders?
Hi Paul
i try both ;
No possibility to select an folder or drive that contains the TB profileordner
Are you using Thunderbird portable only or do you have the application installed on your computer as well?
Unfortunately eM Client isn’t probably able to detect the data folder of your portable client, in order to import the data, you’d have to move the directory to where the data for your desktop version of Thunderbird are located.
Then you should be able to see the accounts/folders for import in the above windows.
