How do I send a meeting invite from the iCloud calendar? I can create an event in iCloud, but it will not send it to an invitee. I can only get this to work in the local calendar.
when you are creating new event then in Scheduling tab is button add, there you will add emails of people you want to invite.
After clicking on save button it will ask you if you want to send invite or not.
if this is not working for you then I will need your CalDAV logs. go to tools - settings - advanced, check CalDAV under your iCal account, apply and restart eM Client.
then create meeting with invitation and send invite, after this click on send & receive to synchronize.
Now send logs… to [email protected] together with this topic’s url in subject.
regards
Jan
