I created event for iCloud Calendar for longer then 24 hours.
In my case 7 Aug 23:15 to 8 Aug 23:50.
Then synchronize with eE Client.
But this event is not visible.
If I update end date to 7 Aug on my iPhone (end time is not changed), then event becomes visible in eM client.
If I return end date to 8 Aug it disappears again.
can you export this event and send me it to: [email protected] together with this topic’d URL?
you can export event by right click on it and save as…
regards
Jan
Why it should be outdated? In that posts are informations that I need you to do if you still need help with this issue.
regards
Jan
It seems there is no issue any more.
When I tried to test more thoroughly, I noticed that if event crosses date border it is moved to the top of the calendar pane - this is what I missed when posting this issue.
Sorry
Ok, thank you for your update on this issue, if it will ever come again don’t hesitate to contact us.
regards
Jan
