Meanwhile I updated to 6.0.23181.0 and turned on logging.
Will report back if it happens again, thanks so far …
Stefan
Stefan
Stefan
It still happens in 6.0.23181.0
I have the log and a screenshot for you.
Hello Stefan, sorry for the belated reply, I’ve resubmitted your logging data to the developers for more information, unfortunately the logs are being reviewed and we’ll try to improve the application’s behaviour for future release. However based on the error you’re experiencing I’m guessing you’re being denied access to a certain folder - meaning your account does not have the sufficient right for writing for example. If you’ve for example tried to import an event into the folder it might be causing this issue.
Repairing the specific calendar should allow you to remove the item of the calendar. However this is just my personal guess from taking a look at the logs.
Hi Paul,
no, I have the sufficient rights. This also isn’t imported data, all has been created using eM Client. Also I can remove such items with no problems or modify them. The problem only happens in the popup window.
Stefan
