I would like to move eM Client's mail folder to a PenDrive (USB flash drive)! How can I do that?
Currently I am using Mozzila Thunderbird 24.3.0.
The program files are installed on my C: drive,
but the profile folder is on my PenDrive (USB Flash Drive).
I would like to switch to eM Client (the Pro version),
but want to keep storing my emails on my PenDrive.
How can I do that?
I found a way:
I move the entire
“C:\Users\MyUserName\AppData\Roaming\eM Client”
folder to my PenDrive, then in
“C:\Users\MyUserName\AppData\Roaming”
folder I create an NTFS soft link with the following command:
mklink /D “eM Client” “T:\eM Client Test Folder”
This is working well! But it is a little bit tricky solution…
Is there an official way to do this?
I did not found eM Client mail folder in Windows Registry…
I know, it is not recommended to store mail folder on PenDrive
because it can be slow (mine is not, because I use a TrueCrypt
image on the PendDrive as T:) and data can be corrupted
(I backup the entire image often).
Hi, eM Client is not supported as portable version and because of that I do not suggest it.
Any issues caused by this will not be supported.
Jan
I see.
I think I will wait for a eM Client Portable version…
Portable version is not planned or considered at this moment.
Jan
Just please make it so that non-elevated users can install.
@Limpar_Andras
You can suggest a Portable version install for others to vote on via the Sleekplan page below.
However a USB-Pendrive install would be “a very limited / very small user base” who would even use that and not likely even worth programming for.
There is though a Chromebook version planned in the Android app you could use as an alternative portable use device on a eg: small cheap 10" size.
@Davide_Gentile
That would normally require the eg: Win / Mac or Linux OS itself to allow that by default, but for security reasons modern OS’s don’t do that.
In the 80s and 90s with eg: Old MSDos / DRDos & Amiga OS & Atari OS you could install “without any permissions” like the new Apollo Amiga OS FPGA does as well.
Surprised you know about ApolloOS and the Vampire FPGA system :wink:
