Hi Ken, if your mail server has auto discover setup correctly on their mail you should be able to setup the account using the automatic setup, just use your email address and password to setup the account.
If not, you can get the recommended server settings on your mail service provider’s website most likely and setup the account manually using the manual setup.
Hope this helps.
