I have 2 pro licenses and one system is no longer operable how can I check the license # on the system I have access to?
As you have pro licenses send in a support request via the menu rather than ask for answers of the forum. After all you are paying for support from the professionals who are very very good in answering queries
Or you can use the License Manager to do it yourself.
Thank you for the replys. But when I do it through the system to get support it takes me here.
If you have a Pro License activated on the computer it should take you to https://support.emclient.com. If you have a Free License activated on the computer, it should bring you here.
But anyway to use the License Manager, you will need the login details sent to you when you purchased the license. There you can see which license is activated on which computer. If you don’t have the login details, you can have them resent to you by entering your registered email address at https://www.emclient.com/reset-password
Or even more simple - just deactivate eM Client on both computers, then reactivate on the two computers you want to use.
