Apparently the diagnostic logs can be quite large. I would like to remove the logs I no longer need and free up the disk space. I have not found a way to do that in eM Client and I cannot locate the files on my hard disk. Is there a recommended way to clean up these files? Where are the located on the hard drive?
I’m not sure if this is the same kind of log you’re referring to, but I checked under Settings > Advanced > Logging. At the top of the dialog there’s a text field showing the location previously assigned for logging. This is how it looks in my case:
C:\Users\MyName\AppData\Roaming\eM Client\Logs
… where “MyName” is my current login name on this computer.
Mike-- Thanks for the tip. That is where I found a whole bunch of old log files going back to 2013. They are now gone. I guess eM Client does not clean these up. This is a good thing for everyone to know.
—tam
