For the last week or so I’ve been getting this message. Very annoying. Where do I go to fix this?
hello? is anyone here? Hmm I was planning to buy this software but seems like no one is home…
we do not offer 24/7 support so that is why my answer is delayed, anyway please follow this https://support.google.com/mail/answe…
with regards
Jan
I did that. Same error. Just keeps coming up over and over again.
Do you have two step verification turned on by any chance?
No - is it possible that Google turned it on for me? Where can I check?
just checked and it appears that it is not turned on…
can you try remove your account and then add it again in eM Client?
I did this - it took about 5 hours to remove the account. I added ti back again and the same message came up. Any ideas?
well, we can check this directly on your computer using teamviewer, if you are not against then please contact me on [email protected] with this topic’s url in subject.
other than this there is nothing else at this moment to be done.
with regards
Jan
