i am not able to create tables
can you please describe what is wrong with the table creation?
Hi
Please find the attached screen short
while writing any thing in the table table structure also moving along with letters
when you fill the other cells with text the size of the cells will accommodate to it and make typing in it easier. You can then make the whole table smaller by dragging the corners of the table, if you need.
The behavior is the same when I test it on my side.
If you have any problem with the behavior you must describe it more, because I don’t see anything wrong from the screenshot.
