Does anyone know of a work around for this? I have the eM client, free version. I did ask for and receive the activation code, and I did enter it on Menu->Help->License.
You are not using the same key on more than one computer are you?
If you are, you will need to register a separate license for each device.
I did indeed try to use the same key on two computers. I’ll get a new key for the second machine. Thanks!!
