Tap Search / Options / Custom folder selection - then tick the folders that you want to search within, tick at the top of the screen to confirm then “X” to close Search Options window.
Click Advanced and enter read:no under the field named has the words.
Within the same window, scroll down and tap Create Search Folder, enter a name for the Search Folder then tap OK.
Hi RobinW,
Great. I am new to emClient and this helped a lot.
It is a bit hidden and the manual is poor at this point.
So thanks al lot for your support.
