By default em Client is using C:\Users\AppData\Roaming\
but I need to use a different folder …
It is not possible …
That is a shame
nobody wants ~1GiB of data on their boot volume …
Unbelievable that in 2012 I am still stuck using Outlook as all the alternatives are hopelessly flawed! Something serious wrong with the world of software development … I guess the nerds aren’t as smart as they think
On your menu Tools -> Settings -> Storage. You can assign a different database under there.
This works if you follow this procedure:
now remember to backup both folders …
I am sorry I did not read it carefully - I thought you posted one question twice so I answered this question https://discourse.emclient.com/emclient/to…
My fault
TNCS: Thank you!
