Maybe I’m to stupid, since I did not found any comment on this, while assuming, this can’t be a rarely used feature…
I’m using caldav calendar, hosted on Synology NAS with owncloud. Works fine.
Now want to create event with inviting people. I can add people from my carddav addressbook, no problem. But, also no use, since those people won’t receive anything. How should they, I did not setup any email address to be used for that. In Thunderbird there’s an option to connect a calendar with an email address, which is then used to send the invitations and receive replies. In eM Client I can’t find something ike that.
Any idea?
B.t.w., using any part of Google & Co. is NOT an option. (I wonder, why it is for some people, however ;-))
Hi, unless your CalDav account does not support advanced scheduling, you unfortunately need to have an email account setup in the application in order to send out invites from this calendar.
